15
Check for uneven display glass before sticking Tempered Glass to it
Do you have non-flat display issue on your OPO?
  1. No
  2. Yes
Results are only viewable after voting.
  1. shahuljannathi
    Ice Cream Sandwich Jan 19, 2015
    shahuljannathi , Jan 19, 2015 :
    any pictures??
  2. sukanta76
    Honeycomb Jan 19, 2015
    sukanta76 , Jan 19, 2015 :
    the man with dented phone !:) a remarkable coincidence to have two phones ( both top quality) dentedo_O
    shubhamgulati91 likes this.
  3. manishv
    manishv , Jan 19, 2015 :
    yeah, reapplied(removed it completely) it 5-6 times because of the bent in the TG. but, i suggest u to not repply because u have very few lints ;) if u reapply u will get few more lints :p i reapplied because i had to remove the bent ;) even, i have lints now
  4. shubhamgulati91
    shubhamgulati91 , Jan 19, 2015 :
    hehe, lints on my tg are not even visible from 30 cm away :p not taking it off
    You Orzly TG had a dent? My Orzly was fine, but my OPO had a dent on Gorilla glass.
  5. shubhamgulati91
    hehe. thanks. Dents on nexus 5 are fairly common, even few friends have it on their Nexus.
    And on OPO.. Well.. Anything is possible with opo :D
  6. manishv
    actually i bent the corner by mistake while applying
  7. shubhamgulati91
    Oh man that must have hurt. Orzly is rare thing in India. Infact I am not able to find any link to order another one. Amazon does not have it in stock.
  8. amithsharma86
    Froyo Jan 19, 2015
    amithsharma86 , Jan 19, 2015 :
    Some one who is aware of all the issues should post the possible issues that one should check after purchasing the OP.
  9. shubhamgulati91
    OP updated with pictures.
    shahuljannathi likes this.
  10. shubhamgulati91
    Sure. OnePlus forum moderators will take the thread down.
    amithsharma86 likes this.
  11. shahuljannathi
    i ll check it once my opo is back :eek::confused:
  12. shahuljannathi
    something is making me to think that it is because of the bottom being curve :oops:o_O
  13. shubhamgulati91
    Nope. That must not be the reason. The top has the exact symmetric curve. But there is no dent on the top edge. Implies the issue is not due to the curve.
    Lets wait for some members to check for the issue on their opo and report back.
  14. blackscorpio
    Froyo Jan 19, 2015
    blackscorpio , Jan 19, 2015 :
    Thanks for the pictures. My order is due for delivery on wednesday, I will check it first thing.
  15. pushkaljn
    pushkaljn , Jan 19, 2015 :
    Dude.. How are u so confident on ur tempered glass.. That u are blaming OPO.. Nilkin had no issues with u.. "probably because of better glue"..it means orzly uses bad glue?
    I don't take it.. Ur installation went wrongdoer ur tempered glass is faulty. Take it with a pinch of salt.. Don't blame opo and spread bad word..
  16. shubhamgulati91
    I had the same issue on Nillkin. Dent was visible with Nillkin TG on. But Nillkin managed to stick on the dent while Orzly didn't. If the dent were not on the display, Nillkin would not show bent image of the tube-light.
  17. pushkaljn
    So u have a curved screen... Congrats... LG is charging premium for it.. Lol
    Still.. Tube-light curved.. Did u check the reflection with other phone.. Lol
  18. shubhamgulati91
    What's there to check on other phones? You trying to say all phones have dent?
    #38
  19. pushkaljn
    If you really want to check a curve.. The right test would be to keep phone on flat surface with screen down.. N tap on the back to see if the phone moves.. This will solve concave . take flat glass surface.. Put a translucent polythene between the flat glass and screen.. Then view it from bottom.. If a dent then will see some air between the surface..
    #39
    dhirajmishra likes this.
  20. shubhamgulati91
    Yeah. Thanks!
    #40
