Chrome draining battery
  1. Vedant620
    Ice Cream Sandwich Apr 5, 2017
    Vedant620 , Apr 5, 2017 :
    Title pretty much sums it
    started day before yesterday, didn't pay it much attention, but then it started sucking up battery like a *****
    And yes before other ppl pounce upon me, I did "use the search function" and from that I've done the following
    1-Cleared chrome's cache
    2-Cleared chrome's entire data
    3-Wiped system cache
    4-Force stopped it numerous times
    All to no avail
    PS: Suggesting another browser is not a solution
  2. Vedant620
  3. G_raghav_batra_QiEx
    Donut Apr 5, 2017
  4. mmddmm1702
    Honeycomb Apr 5, 2017
    mmddmm1702 , Apr 5, 2017 :
    Same here ... With like 15 tabs open usually it is the top battery sucker ... But was worse ... Since version 56 it is less.
    Lord_Babass likes this.
  5. Vedant620
  6. Sun90
    Starting Point Expert Community Expert Apr 5, 2017
    Sun90 , Apr 5, 2017 :
    Try updating it and see.
    You will find the latest version on apkmirror.com
  7. Francisco88
    Froyo Apr 5, 2017
  8. Vedant620
    it's the latest version itself.... downloaded directly from Google play
  9. Sun90
    Try disabling background data for it and see.
  10. sommersy
    KitKat Apr 5, 2017
    sommersy , Apr 5, 2017 :
    I've noticed this too, particularly on official OOS. you can FC it all you like, but it won't stay closed on its own. probably not something that can be fixed without root.
  11. jim262
    jim262 , Apr 5, 2017 :
    You guys need to SEARCH! I have run Chrome as my browser also.
    SEARCH and "Never Settle"!
  12. Vedant620
    will try that for sure
  13. Vedant620
  14. jim262
    No you didn't. There are videos on YouTube, articles on places like XDA and Android Authority and I have seen many suggestions on this site alone, plus I have posted links many times.
    freddyabbes likes this.
  15. jim262
  16. Vedant620
    maybe you could outline as to what exactly I missed, if you read my thread you'd see I did actually do a bunch of options, also, if you're gonna suggest that I wipe my data just cause an app isn't working then I'm sorry to say factory reset is not always (or atleast should not always be the answer)
    regarding search, I did a proper Google search as well along with a forum search, that turned up mostly 2012, 2013 articles, this one was the most recent one I was able to find and the solutions outlined by it, I'd already tried and neither worked for me nor the OP of that thread
    forums.androidcentral.com/nexus-5x/604750-chrome-devouring-battery.html
  17. jim262
  18. jim262
  19. Sandeep varma
    Gingerbread Apr 6, 2017
    G_Mark_Dunn_JMmj and Vedant620 like this.
  20. Abhi0710
    Cupcake Apr 6, 2017
    Abhi0710 , Apr 6, 2017 :
    Is chrome really the culprit.. Coz on my galaxy note 4 haven't experienced any battery drain.... I think the oxygen OS after nougat has this battery drain issue in OP3T
