4
Chrome Freezing On Oneplus 8 Pro Devolepor Pls fix ! via OnePlus 8 Pro
  1. Mert Yıldırım (Tr) , via OnePlus 8 Pro , Aug 1, 2020 :
    Hello Community,
    İhave Problem With my First oneplus 8 pro 12/256gb Smartphone Ehen i everytime using a Chrome is Freezing every 2 min can someone Pls fix it on 8 series i mean this device is high end but this problem is very big...
  2. Swejuggalo
    Lollipop Aug 1, 2020
    Swejuggalo , Aug 1, 2020 :
    Everything that happens with a browser is not always a problem with the OS or in control over by OnePlus. Issues with Chrome is not unique to Oxygen OS. Even Pixels can have issues with it.
    However....since this was released for 6/6t maybe some changes are comming to other devices too.
    HS Athwal likes this.
  3. Miguellx
    Cupcake Aug 2, 2020
    Miguellx , Aug 2, 2020 :
    oneplus 8 pro 12/256gb user.
    0 problems with Chrome freezing or crashing so far...
  4. Neerajan
    Honeycomb Aug 2, 2020
    Neerajan , via OnePlus 8 , Aug 2, 2020 :
    Hi,
    I have been OnePlus 8 and have experienced chrome crashing suddenly. It is not very common tough. If it is a issue with all Android devices, then I am sure it would have got a huge media attention. but there isn't anything of that sort. Which makes me wonder is it happening only in OnePlus devices? Or since OnePlus devices always receive early updates, may be the issue is now prevalent only in OnePlus devices!!
    Anyways, it is not a key issue which can hinder the user experience. But it will be much better if it's fixed either by Google or OnePlus.
    HS Athwal, Nitingup00 and Nikhil1358 like this.
  5. F_Tony_DeMartino_hjHI
    Ice Cream Sandwich Aug 2, 2020
    F_Tony_DeMartino_hjHI , via OnePlus 8 Pro , Aug 2, 2020 :
    I randomly have the freeze issues where the screen doesn't respond to scrolling but if I press the power button and unlock again it goes back to normal. A little annoying but it's not a big deal.
  6. ashwinmurali
    ashwinmurali , via OnePlus 6 , Aug 2, 2020 :
    I do have the same issue in my op6 and now it is resolved after the latest update.
    HS Athwal and Swejuggalo like this.
  7. Swejuggalo , via OnePlus 8 Pro Ultramarine Blue , Aug 2, 2020 :
    Some already said it didn't help them though. But there could be multiple issues people have. Some might just need to update Chrome too or reset it via wiping the app data.
  8. #8
  9. Swejuggalo , via OnePlus 8 Pro Ultramarine Blue , Aug 3, 2020 :
    If we have the same issue as they fixed in 6/6t series latest update I assume we get a fix soon too. However I doubt all issues are on Oneplus to solve since many other phones have issues too.
  10. fragargon
    Jelly Bean Aug 3, 2020
    fragargon , via OnePlus 8 Pro , Aug 3, 2020 :
    It did had huge media attention, it's a matter on how search is performed.
    https://www.google.com/search?q=chr...0l4.10169j0j7&sourceid=chrome-mobile&ie=UTF-8
    Neerajan likes this.
  11. Neerajan
    Honeycomb Aug 3, 2020
    fragargon likes this.
  12. Adrian1976 , via OnePlus 8 Pro Glacial Green , Aug 3, 2020 :
    I have never seen this issue in pixels and galaxy's I've owned, this is the first time I've seen chrome freezing.
    Maybe it's a combination of OP and Chrome but I have never encountered this issue on any other phone I've owned.
  13. fragargon
    You don't need to apologize buddy, there no offense .
    Btw I used Chrome beta V85 which is now on 64 bit.
    It works much better, don't have freeze since.
    M2c
    Huigiebaby and Neerajan like this.
  14. dc2royce
    Cupcake Aug 4, 2020
    dc2royce , via OnePlus 8 , Aug 4, 2020 :
    Same here. OP8, latest stable oxygen os build, latest chrome version. happened from day 1.
    switching to chrome dev and different webview version seemed to help a little bit but came right back. c'mon OnePlus this a brand new phone.
    Going to try chrome beta now.
  15. Huigiebaby
    Ice Cream Sandwich Aug 5, 2020
    Huigiebaby , Aug 5, 2020 :
    Top tip, not a single freeze since I installed it!
  16. U1596566166276
    Cupcake Aug 5, 2020
    U1596566166276 , via OnePlus 8 Pro , Aug 5, 2020 :
    I am facing the same issue
  17. E1588609996056
    Cupcake Aug 5, 2020
  18. #18
  19. Huigiebaby
    Ice Cream Sandwich Aug 7, 2020
    Huigiebaby , Aug 7, 2020 :
    DID YOU INSTALL THE BETA?
  20. Swejuggalo , via OnePlus 8 Pro Ultramarine Blue , Aug 7, 2020 :
    Some stuff also is different from user to user. Not everyone use Google backup that messes things up by importing some app data even efter an reinstall. Some use stable and some use beta...
    Some guy had a really badly behaving version months go... He disabled Google backup and wiped Chrome app data. That fixed it for him that time.
    Adrian1976 likes this.
