21
Cinema FV-5
  1. EXIV
    KitKat Mar 26, 2015
    EXIV , Mar 26, 2015 :
    I am sorry to hear that, maybe you are using a mic with a wrong connector.
  2. EXIV
    KitKat Mar 26, 2015
    Thanks a lot! It's a pleasure to receive such compliments! I'll share much more :)
    Neth likes this.
  3. Vadomata
    Jelly Bean Mar 26, 2015
    Vadomata , Mar 26, 2015 :
    Maybe. Any idea if Rode connectors are sold on ebay? I bought mine from local gadget store. I believe it's TRRS.
  4. Reus
  5. jlg1234
    Honeycomb Mar 26, 2015
  6. gmo8492
    Lollipop Mar 26, 2015
    gmo8492 , Mar 26, 2015 :
    Great review, the thing that bothers me is no front facing camera support.
  7. grav3h3art
    grav3h3art , Mar 26, 2015 :
    That's great! Looking forward to it.
  8. T3STY
    T3STY , Mar 26, 2015 :
    4K UHD available here. If you don't buy the app the high resolution recording sizes won't be available.
  9. Alexhibition
    Froyo Mar 26, 2015
  10. script
    Moderator Moderator Mar 27, 2015
  11. sloganc69
    Honeycomb Mar 27, 2015
  12. dev@rshi
  13. T3STY
    T3STY , Mar 27, 2015 :
    Probably it's because I'm using CM12 nightlies. I can't remember where I read that some features were only available on Lollipop.
    Alexhibition and script like this.
  14. script
    script , Mar 27, 2015 :
    I was also wondering, because I read the same somewhere. Maybe it was an update message from the app itself.
  15. EXIV
    KitKat Mar 30, 2015
    EXIV , Mar 30, 2015 :
    Here is the full answer from the guys of Cinema FV-5 http://exiv.tv/cinema-fv-5/
  16. sinn5Lmandala
    Cupcake Dec 16, 2015
    sinn5Lmandala , Dec 16, 2015 :
    Hi, I am facing the problem that I cannot record audio from an external mic. Have you found a solution in the meanwhile?
  17. Vadomata
    Jelly Bean Dec 16, 2015
    Vadomata , Dec 16, 2015 :
    I've had this too, but I once got it working. Only way is to record with external recorder and edit the clip.
  18. sinn5Lmandala
    oh my. that's dissapointing. nevertheless: thanks.
    #38
    Laamapalmu likes this.
  19. vivekpandit
    Cupcake Feb 2, 2016
    vivekpandit , Feb 2, 2016 :
    Hi cinegiak, I have tried to use your solution to get an external mic on the oneplus.
    And as you have rightly pointed out, the video quality/color/focusing takes really bad hit .
    Any tips to fix that ?
    I have some sample videos with external mic connected to the oneplus one at the end of this video.
    Disclaimer: This video is more targeted at beginners, if you just want to look at the sample feel free to skip to 02:40
    This is the mic I used: Røde VideoMicro
    #39
