70
[Closed] 4.0.2 in Works. Roll-out by Next Week. CONFIRMED
Thread Status:
Not open for further replies.
  1. Moin2200
    KitKat Jan 15, 2017
    #81
    Deactivated User likes this.
  2. noquarter
    Lollipop Jan 15, 2017
    noquarter , Jan 15, 2017 :
    Quite old news.
    Thread merged
    #82
    Sun90 likes this.
  3. F_Tony_DeMartino_hjHI
    Ice Cream Sandwich Jan 15, 2017
    F_Tony_DeMartino_hjHI , Jan 15, 2017 :
    no such thing as bug free software.
    #83
  4. Maxsteel9
    Froyo Jan 15, 2017
    Maxsteel9 , Jan 15, 2017 :
    I hope for the best and will also believe this with a pinch of salt. Still waiting for my official OxygenOS Nougat version update as well.
    #84
  5. SimonRam
    SimonRam , Jan 15, 2017 :
    True, ask Pixel owners:)
    #85
    F_Tony_DeMartino_hjHI and Sun90 like this.
  6. runboy93
    Jelly Bean Jan 15, 2017
    #86
  7. molty
    Cupcake Jan 15, 2017
    molty , Jan 15, 2017 :
    nougat update is buggy
    I was having trouble downloading apps from the playstore then I read it somewhere that this problem is being faced by one plus 3 and 3t after the nougat update and then it was suggested to switch on battery saver from settings menu and it worked
    this is a bug, please sort this out in your next update
    #87
  8. Baibhav_Kumar
    Honeycomb Jan 15, 2017
    #88
  9. SirBacke
    SirBacke , Jan 15, 2017 :
    What security problem do you have exactly which you want to be solved?
    #89
    kalander Shihab likes this.
  10. banditknight
    banditknight , Jan 15, 2017 :
    Security problems are usually invisible until you get hacked. I believe there have been some security issues fixed in the January Android update. Users may not be aware of their existence.
    #90
  11. Deactivated User
    Jan 15, 2017
    #91
  12. SirBacke
    How awfull!
    #92
  13. larsenfed
    #93
  14. SirBacke
    To exploit the bootloader vulnerability you must give someone your handy to make use of it, or he must get remote access to an adb connection to the device. Also he must be an extremely highly sophisticated professionel to know and understand how to make use of such a vulnerability. The chance is probably about 1:10'000'000 or even less that someone gets affected. Talking about such things on a Google phone which is full of spyware and backdoors is just ridiculous. Most of the users don't care about security at all. They let apps spy at them, save their personnel data and contacts on totally unsecure american servers and then they cry for security updates? Come on guys, lets stay on the ground.
    Because I want only the best for you I give you a small tip:
    Go to Play store, download "Spy Monitor" and have a look to which servers all over the world your Handy is connected in this very moment. But please, don't come back to me and ask me what kind of information these servers are collecting right now from you....... It must not necessarily be a bad connection spying at you. But it can....
    I don't want to say that it is not necessary to solve such vulnerabilities. What I want to say is that it is quite useless to ask for security updates when you even don't know if there are issues, and if yes, if they are dangerous or not.
    As usual, the biggest Problem is behind the display, not somewhere else.
    #94
    Sun90 and SimonRam like this.
  15. Deactivated User
    Jan 15, 2017
    #95
  16. SirBacke
    There are hundreds of other apps spying. Not only, but also Google.
    #96
    Sun90 likes this.
  17. bpwest80
    KitKat Jan 15, 2017
    bpwest80 , Jan 15, 2017 :
    Just do a factory reset. It will solve most of your problems. 4.0.1 is working fine for me and I did a factory reset. Plus if you factory reset you'll get f2fs. It only takes a couple hours to set your phone back up after a factory reset, it's not that big of deal. The suckiest part is signing back into all your apps but like I said, you'll be back up and running in no time at all and your phone won't have all the problems it did before the factory reset
    #97
    1briang likes this.
  18. Rishab Saxena
    Froyo Jan 15, 2017
    Rishab Saxena , Jan 15, 2017 :
    will this work?
    #98
  19. jackiefreaky
    Froyo Jan 15, 2017
    jackiefreaky , Jan 15, 2017 :
    I believe its much needed that the battery issues be fixed first hand since 4.0.1 is snappy already
    #99
  20. Sumanzu
    Froyo Jan 15, 2017
