[CLOSED]Ambien mode for Oneplus 7 Pro
Thread Status:
Not open for further replies.
  1. megoshopping
    Gingerbread Feb 14, 2020
    megoshopping , Feb 14, 2020 :
    i read today oneplus roll out the ambien mode but i am not able to see it.
    here are the steps for enable it...
    google app->more->settings->google assistant->assistant->phone... but the ambien display option is not here.
    can anyone access it??
  2. harshil1903
    Ice Cream Sandwich Feb 14, 2020
  3. megoshopping
    Thanks. I thought all i needed to do was to update Google app.
    Will this be an upgrade from oneplus? If not, how would I know when it's available?
  4. harshil1903
    harshil1903 , via OnePlus 7T , Feb 14, 2020 :
    It won't be an update from OnePlus. Google will push the update. You won't have to update the Google app either.
    You know the steps to activate it. So keep looking for the option regularly. Or it'll be automatically available as a notification when you plug your phone to charge it. So you'll know that your device has received the update.
    DRCH likes this.
  5. DRCH
    German POC Assistant Head Moderator Feb 14, 2020
    DRCH , Feb 14, 2020 :
    Well said ;)
  6. barnabyj
    Honeycomb Feb 14, 2020
  7. Gav_W86
    Starting Point Expert Feb 14, 2020
    Gav_W86 , Feb 14, 2020 :
    it is a server side enable by Google. You will get a pop up when you have the phone plugged in when it is enabled.
  8. megoshopping
    DRCH likes this.
  9. akks
    Jelly Bean Feb 14, 2020
    akks , Feb 14, 2020 :
    I got the notification yesterday morning while charging. Used that crap for a day and I disabled. It's simply a gimmick. Just another lock screen which needs to be swiped away before accessing the fingerprint unlock.., also when we recieve calls, it come as small notification bar on the top, as if we are using the phone. So stupid thing as far as I'm concerned.
  10. DRCH
    Since you're question is answered now, I will close this thread :)
