[Closed]Battery & 5G via OnePlus 8T
Thread Status:
Not open for further replies.
  1. Bernest44
    Honeycomb Feb 28, 2021
    Bernest44 , via OnePlus 8T , Feb 28, 2021 :
    There will be complaints about call recording....one handed mode and so on. But One Plus is really just a phew tweaks away from a great performing mid ranger. Battery drain/ heating and making sure the 5G shows as an option in Preferred Network Settings.
  2. Cervantes
    Moderator Moderator Feb 28, 2021
    Cervantes , Feb 28, 2021 :
    Hello
    You can check the OP8T forum
    Please, use the latest update thread for questions and comments, read the first post
    in the first post you have information to report a bug
    use the battery thread for battery and heating problems: Here
    for another user to suggest: upload a screenshot of:
    battery and other
    battery uses
    Install cpuz: check temperature
    Use the search engine before opening a new thread: Search
    Read the forum rules: Rules
    Thread closed
