[CLOSED] Battery drain 4.0.3
Thread Status:
Not open for further replies.
  1. nizklaz
    Donut Feb 21, 2017
    nizklaz , Feb 21, 2017 :
    Since I upgraded to the latest Oxygen OS, my battery has started to drain much faster than before. Anyone got any solutions?
  2. nizklaz
    Donut Feb 21, 2017
  3. Chitt Kapadia
    Eclair Feb 21, 2017
  4. G_Giorgos_Savva_UjKi
    Cupcake Feb 21, 2017
  5. nemezida
    Eclair Feb 21, 2017
    nemezida , Feb 21, 2017 :
    yes there is a solution. wait and very soon will be released new update to fix that problem.
    for me is more speaker low volume is worries after 4.02 started. hopefully they will fix that too
  6. Onkar.Singh
    KitKat Feb 21, 2017
    Onkar.Singh , Feb 21, 2017 :
    If its only the Android system and OS, you ought to turn off the Backup and Reset option in Settings.
    Also, reset the Google Play services ...
    Go to Settings > Apps and tap on Google Play Services.
    Once in, tap on Storage > Manage space and then tap on Clear All Data.
    Check this out as well >>>
    https://forums.oneplus.net/threads/...-battery-drain-issues-with-this-trick.491970/
    Hope this helps resolve the battery issues ....
    The basic rule ... Ensure that you back up your data before executing the below mentioned ...
    Update all apps from Play store to latest version.
    Charge the battery to 100%
    Boot in recovery Mode and delete cache.
    Do the update to the next version.
    Factory reset the device once the update is completed
    Fresh install apps from PlayStore and update them to the latest version.
    Investing the time in all these usually ensures smooth transitions ... Worth it !!!
  7. Master_TC
    Jelly Bean Feb 21, 2017
  8. gubro
    KitKat Feb 21, 2017
  9. gaster
    Lollipop Moderator Feb 21, 2017
    gaster , Feb 21, 2017 :
    Please use the search function before posting. There are already threads with a similar content. I will close this one
    Funk Wizard and pablofg1978 like this.
