[CLOSED] Battery draining drastically.
Thread Status:
Not open for further replies.
  1. ThrowingTitan
    Froyo Sep 17, 2018
    ThrowingTitan , Sep 17, 2018 :
    As you can see, today i had put my phone on Airplane mode and then too my battery is draining drastically without even using it. i havent even used Instagram for more than 20 mins all together but it has used almost 6 percent. i havent even used my phone today nor made any calls. After this Pie update,there has been battery problem atleast for me. But i can even see other people on the forum here are facing the same problem on this Pie update. Please fix the battery issue in the next update. Battery was good in Nougat.Please fix it.
  2. Deactivated User
    Sep 17, 2018
  3. tortoise14
    Honeycomb Sep 17, 2018
  4. Suri1019
    Cupcake Sep 17, 2018
  5. iam.saahil
  6. J1532844518029
  7. pablofg1978
    Spanish POC Assistant Head Moderator Sep 17, 2018
    pablofg1978 , Sep 17, 2018 :
    use the official beta thread for any issues with the beta
    Pointless thread closed
