[Closed] battery draining fast
Thread Status:
Not open for further replies.
  1. prb23
    Cupcake Aug 23, 2019
    prb23 , Aug 23, 2019 :
    I have been a satisfied one Plus 6 user untill last os update. now I have 9.0.8 . My battery usage is almost same every day. before the update my battery used to last 18+ hours. now the battery is draining drastically. I will appreciate any help. thanks
  2. prb23
  3. U1546664152551
    U1546664152551 , Aug 23, 2019 :
    same issue here. And others also seem to face this since long time. If there is no solution,then I'm not sure how long I'll be loyal to OnePlus.
    prb23 likes this.
  4. prb23
    same here. I like one plus only because of fast charging and battery .. but if that's not there then I doubt I will continue with OP .
  5. Prafful36
    Prafful36 , Aug 23, 2019 :
    i am facing the same problem. the battery freezes for a couple of hours and then it drains drastically.
  6. W1556961774113
    W1556961774113 , Aug 23, 2019 :
    I am a 6t maclaren user. its sad to say that my phone is lagging while playing pubg. it's so laggy now a days that I couldn't even play. and the battery draining issue is also a prominent issue for me too.
  7. O1566552066176
  8. Funk Wizard
    Lollipop Moderator Aug 23, 2019
    Funk Wizard , Aug 23, 2019 :
    Please discuss the details in the existing update thread instead of creating new threads.
    Stable | Beta | Android Q
    Thread Closed
    Kytharsis likes this.
