[CLOSED] Battery issue
Thread Status:
Not open for further replies.
  1. nirmal783
    Cupcake Sep 4, 2018
    nirmal783 , Sep 4, 2018 :
    Hi guys,
    I am having a battery issue when I fully charge my phone to 100% and then use it in routine. The drainage from 100 to 60 is too fast and then it drains on a medium scale. Also the overall drainage has depleted to half a day, which means the 100 battery dies in half a day and so I have to charge my phone 2 times a day. Could you guys please resolve it through a software update maybe or do I need to go for replacing the batteries ?
    Please suggest.
  2. Nits_G_
    Eclair Sep 4, 2018
    Nits_G_ , Sep 4, 2018 :
    well OnePlus has dash charge so it's no big deal I also charge it twice a day
  3. nirmal783
    Cupcake Sep 4, 2018
    That's not an issue at all, but if I keep the phone offline and not use it, then also it drains the batteries.
  4. Nits_G_
    Eclair Sep 4, 2018
  5. nirmal783
    Cupcake Sep 4, 2018
    So that can be resolved by software update, right ?
  6. Nits_G_
    Eclair Sep 4, 2018
    I mean it can be and according to OnePlus they have already done it in the last patch but to be honest it's still the same
  7. nirmal783
    Cupcake Sep 4, 2018
    Yeah exactly.
  8. Nits_G_
    Eclair Sep 4, 2018
    if there is a major issue like 30-40% battery drop on no usage then contact OnePlus
  9. G_Jassi_Anand_fWrv
    Eclair Sep 4, 2018
    G_Jassi_Anand_fWrv , Sep 4, 2018 :
    I would suggest a full wipe for this.
    if you can't perform that alteast clear cache from settings and recovery both & check for 2-3 days.
    Remember, Gps, low network reception, sensors, live wallpaper, gaming mode, things like these do drain battery faster.
  10. Nits_G_
    Eclair Sep 4, 2018
    10% is considered normal
  11. frankkn85
    Eclair Sep 4, 2018
    frankkn85 , Sep 4, 2018 :
    if you are using myjio app then disable it from popping up assistant in setting of app it will improve battery life.
  12. Nits_G_
    Eclair Sep 4, 2018
  13. pablofg1978
    Head Moderator Head Moderator Sep 4, 2018
    pablofg1978 , Sep 4, 2018 :
    Please use the pinned battery thread in the support section for any battery related discussion
    Pointless thread closed
