[CLOSED]Battery life significantly reduced on 4.0.3 after a week.
Thread Status:
Not open for further replies.
  1. shubham096
    Eclair Mar 10, 2017
    shubham096 , Mar 10, 2017 :
    I've updated my OnePlus 3t to oxygen os 4.0.3 almost 2 weeks ago. After updating I was getting very good battery backup with screen on time around 7 hours. now I'm getting 4.5 to 5 hours of screen on time . this is happening from 4-5 days.
    Can someone help me.
    I've tried clearing cache in recovery and cleared data of Google play services
    this was my battery backup after updating.
    now I'm getting this.
    Google play services and Android system are draining my battery.
    G_priyam_tayade_qstc likes this.
  2. Priyam Tayade
    Cupcake Mar 10, 2017
  3. Fursan Afzal
    Ice Cream Sandwich Mar 10, 2017
    Fursan Afzal , Mar 10, 2017 :
    We'll have to wait for the next update.
    Oneplus has a history of instability in it's softwares sadly they rushed the nougat update too.
    This 4.0.3 update brought battery drain with it (updates are meant to fix problems not cause them)
  4. Master_TC
    Jelly Bean Mar 10, 2017
  5. ebernal85
    Donut Mar 10, 2017
  6. iAnkur
    Gingerbread Mar 10, 2017
  7. BobbyV8_
    The Showcase Reviewer Mar 10, 2017
    BobbyV8_ , Mar 10, 2017 :
    Dude SOT is not everything. try the guide suggested by @Master_TC and move on, you have a lot of usage on insta & also there seems to be some service stuck running in the background from play services. However, 4-5 hrs SOT is pretty good. 7hrs is when usage is less on other battery draining apps.
    Even then your mobile lasted for bloody whooping 23 hrs & you still complain!! pretty bad
    Redeclipse and Tony L. like this.
  8. bun.pun
    shubham096 likes this.
  9. shubham096
    Eclair Mar 10, 2017
  10. shubham096
    Eclair Mar 10, 2017
    dude I was using Instagram more when sot was 7 hours. I'm not using even using any Google app since last charge still Google play services are using most battery.
    I know sot is not everything but with less phone usage then before its still not lasting a day.
  11. G_ganesh_dalvi_rsTO
  12. BobbyV8_
    But it was not visible in your screenshots dude.
    You have misread me. I said some process is stuck. clear play services cache from settings, cache from storage under settings, also from recovery. it might help clearing those processes.
    Battery backup depends on lot of issues. you just have to figure out which app is draining
  13. alencode
    alencode , Mar 10, 2017 :
    7 HS on 10%?? that is very normal. Remember that this device is not a monster like Moto z play, the 821 consume a lot but in his range.
  14. alencode
    Sorry, I didn't see the second ss,, that it's problematic, almost 4 hours. Strange.
  15. jdyadav93
  16. Aniket_Apte
    Donut Mar 10, 2017
    Aniket_Apte , Mar 10, 2017 :
    Same issue here as well.. I get 4 hrs SOT. I used to get 5 to 6 hrs SOT in Marshmallow with exactly same usage as of now..
  17. Suryavanshiparesh
    Suryavanshiparesh , Mar 10, 2017 :
    not only battery but even nevigation(back and recent button) does not works and finger print doesn't scan even after maximum attempt and want to draw pattern lock just like a ordinary phone
  18. Suryavanshiparesh
    when discussed this issue with service centre the. they doesn't accept and they got only solution for this issue is to just do software.....
  19. Smilirulz
    Smilirulz , Mar 10, 2017 :
    dude, you have at least 24 hours of battery since last charge. what do you want more than that, ffs? its just a 3400 battery, not a 6000 one. theres no phone on the market at this moment with the same battery capacity to get you through 24 hours. f**k SOT, sot doesnt mean anything. for example, ive played rummy with my friends like 8 hours a few days ago, and i had 8,5h sot, with 9% left, next day ive used it without playing rummy at all, just browsing and youtube and got 4 h SOT with 10% left, but in both cases it took me over 20 hours of battery, which is phonomenal. its all about the apps you are using, and also what internet connection you are using.if battery takes you through more than 20 hours, be thankful and enjoy your phone for the rest of its life
  20. Ankitasaha87
