2
Battery/Charging [CLOSED] Battery not charging
Thread Status:
Not open for further replies.
  1. 3mrys
    Froyo Feb 9, 2017
    3mrys , Feb 9, 2017 :
    so, my OPT ran out of battery. usually, when i try to charge the phone, it will show big battery icon charging right? but it didnt just now. it showed a message saying "battery is too low, charge for a while before turning device on" with battery icon. the problem is, it seems like i cant charge my device. i leave my device to charge for like 3 hours, the same message appear and the battery percentage didnt go up. i tried to charge the phone using other charger (same cable) but it wont work. anyone know what is the cause and how to fix it?
    G1581590483632 and maheshrshet like this.
  2. 3mrys
    Froyo Feb 9, 2017
    update :
    so, i try to access the recovery, failed. but when i plug the phone on my laptop, the phone turn on and in recovery mode.
    G1581590483632 likes this.
  3. Kiran.a.joseph
    Jelly Bean Feb 9, 2017
    Best Answer
    Kiran.a.joseph , Feb 9, 2017 :
    When this issue happens, remove the charger and then resume charging after 30 to 60 seconds. Then the phone will start charging.
  4. 3mrys
    Froyo Feb 9, 2017
    i tried it, still got the message. i will just leave it for a while to see it works or not
  5. 3mrys
    Froyo Feb 9, 2017
    wow! its work! thanks a lot dude!
    Kiran.a.joseph likes this.
  6. Irfan.malik
    Cupcake Feb 28, 2017
    Irfan.malik , Feb 28, 2017 :
    I had the exact same issue today! Ran out of battery and when I plugged in the charger, nothing happened.
    I tried everything as in this threat but didn't work.
    the only way it worked is when had the phone connected to a computer and I long pressed the power button and the menu key together (out of frustration) and the battery icon with charging symbol came on.
    now it works normal.
    OnePlus please have a look at this issue.
    kalyani0493 likes this.
  7. G_Saifuddin_Mohit_ucvj
  8. mm2
    Eclair Feb 28, 2017
    mm2 , Feb 28, 2017 :
    Recently I also ran out of battery. When I connected the charger it showed me the same msg- battery too low, charge for some time before switching on.... I kept charging for 30 mins n then started the the phone.... I had no issues....
    anagha004 likes this.
  9. anagha004
    Cupcake Mar 1, 2017
    anagha004 , Mar 1, 2017 :
    Thank you guys. It helped.
    PATIENCE is the key here.
    You just need to have some patience till it gets charge a bit. :| :|
    which is really difficult.. i tried power button plus volume low key on n off several times. and wasted almost 3 hours and when i got tired, i left the phn connected to charger just for 15 mins and it returned back to life.. phew... :)
    i will never allow it to drain till 0% now onward :|
  10. sankuraj
    Cupcake Mar 4, 2017
    sankuraj , Mar 4, 2017 :
    Similar Problem I am also facing. "battery is too low, charge for a while before turning device on" - This message is being displayed. Disconnected the charger even waited for hour tried to recharge. But still getting the same message. Even tried to charge over 5-6 hours. Result is still showing ZERO.
    Please advise.
  11. sankuraj
    Cupcake Mar 8, 2017
    sankuraj , Mar 8, 2017 :
    The problem resolved after I changed USB cable [e]1f602[/e]
  12. arvinddhaka99
    Donut Mar 8, 2017
  13. Hitesh Koirala
    Cupcake Mar 9, 2017
    Hitesh Koirala , Mar 9, 2017 :
    I am having similar problem but not so similar .My one plus 2 is having problem. The battery gets down while charging. Battery drains very fast. I change battery but problem still appears.... any one can give me solution . I did everything what I found in you tube. Please suggest....
  14. vbv verma
    Cupcake Mar 30, 2017
    vbv verma , Mar 30, 2017 :
    Hold the power button , till phone restarts for 5th time. Let it start and set the time again if it asks. Charging will begin after that.
  15. anupshakya
    Cupcake Apr 1, 2017
    anupshakya , Apr 1, 2017 :
    Happened to me too... was playing a game while my OPT was around 29% charge... After a while of playing, the mobile vibrated, the screen went off ... then the phone seemed like it was rebooting (the one plus start up logos turned up), but then the mobile didn't turn on.
    I tried the 5 times 20 seconds power button hold, plugged in the charger for 3 hrs, pressing power and volume button to try to boot to recovery mode. Nothing worked. :(
    Still can't get my phone to turn on. Can you suggest anything?
  16. kalyani0493
    Cupcake Feb 8, 2020
    kalyani0493 , Feb 8, 2020 :
    Thankyou so much @Irfan . This worked for me too.
  17. N1593061711404
    Cupcake Dec 17, 2020
    N1593061711404 , Dec 17, 2020 :
    ~happened same with my oneplus 3, if your problem is solved can you tell me how to fix this isssue
  18. pablofg1978
    Head Moderator Head Moderator Feb 22, 2021
