2
[CLOSED] battery
Thread Status:
Not open for further replies.
  1. Rasheed_Belus
    Cupcake May 16, 2017
  2. nickpsil
    Honeycomb May 16, 2017
    nickpsil , May 16, 2017 :
    hmmm yup sorry to say so , it is not the signal to say the truth ! it happens everyday all day within all signals . A Xiaomi Mi Max at the same time had 77% of usage !!!!! with the same signal !!!! OP should fix this before they lose their customers !!
    G_Santosh_Patil_TNxO likes this.
  3. G_Prajal_Nandania_gJSo
  4. G_Harsh_Kaur_Khalsa_VwPk
    Donut May 16, 2017
    G_Harsh_Kaur_Khalsa_VwPk , May 16, 2017 :
    completely drain your phone! and then charge it 100 percent without using wifi or any apps! m gonna do the same! if not then! will call the customer care :)
  5. APhaniSankara
    Gingerbread May 16, 2017
    APhaniSankara , May 16, 2017 :
    Hey man now I'm on open beta 6... Battery life was good man.. Maybe 5hr of SOT is enough to use per a day.
  6. G_rajesh_dansena_Puli
    G_rajesh_dansena_Puli , May 16, 2017 :
    Hey devs and 3/3T fans, My onePlus3 battery is lasting just 10-12 hours. Is anyone else facing same issue after Android 7.1.1 Oxygen4.1.3 upgrade? If anyone have any solution please share. Now adays i need to charhe twice in a day.
    PS :
    - Using LATE data whole day.
    - No gaming
    - Usually I do WhatsApp and light weight apps only and most of the time the device is in ideal mode.
  7. KRISHANU SINGH
    KRISHANU SINGH , May 16, 2017 :
    Reset maaro. Slowly install all your apps over a week to find the culprit app. Remove it problem solved.
  8. vallabh budhkar
  9. G_Santosh_Patil_TNxO
    Cupcake May 17, 2017
    G_Santosh_Patil_TNxO , May 17, 2017 :
    Same issue with me. Guess what OnePlus escalation team says - "Yes sir, 7 hours with mixed usage is all that the phone will survive!!" Why the F@#* design a phone in 2016 that can't even survive a day. Or why upgrade the software if not we'll tested!!! Crappy response really!!!
  10. G_Santosh_Patil_TNxO
    It wouldn't help my friend!!!
  11. G_Santosh_Patil_TNxO
    Do you really think we are only meant to test the phone for OnePlus??? I should get paid for it!!!
  12. G_Santosh_Patil_TNxO
    10/12 hours is good man!! According to Mr. Mohan Kumar from the OnePlus escalation team he says "with mixed usage i.e. WiFi and 4G 7 hours is all you will get"!!!! I was soooooooo furious with that reply!!! [e]1f620[/e] Frustrating!!!
  13. saikiran4ever
    Jelly Bean May 17, 2017
    saikiran4ever , May 17, 2017 :
    Next time when you create a thread, give more priority to the title..
    Regarding battery issue, go for lineage os..
  14. KRISHANU SINGH
    Gingerbread May 17, 2017
    KRISHANU SINGH , May 17, 2017 :
    Blame the app that u running not the os that's what i m saying.
    ghostofcain likes this.
  15. Noorul Faheem
    Froyo May 17, 2017
    Noorul Faheem , May 17, 2017 :
    if anyone is a beta tester for any app, that might be the reason for your battery drain.
    moreover over the last one week my phone near the ear piece was heating up after turning on WiFi or mobile data coz of which my SOT dropped from 6+hrs to 2+hrs. and I found the hike app to be the culprit. I uninstalled the app and now it's working great. my SOT is back to normal.
    so try installing hike and leave the app for beta testing
  16. G_Arsallan_Shunthoo_GnXL
    Cupcake May 18, 2017
  17. sunil.phys
    Cupcake May 19, 2017
  18. gubro
    KitKat May 19, 2017
  19. Kishanprasad
    #39
  20. gaster
    Lollipop Moderator May 19, 2017
    gaster , May 19, 2017 :
    Please use the search function before posting a new thread. There is already a thread that you can ask help from. I will close this one. Check here https://forums.oneplus.net/threads/...ues-now-on-one-plus-3-and-3t-os-4-1-3.538112/
    #40
