Battery/Charging [CLOSED]Charging issue via OnePlus 7
Thread Status:
Not open for further replies.
  1. Ajikdevadas
    Gingerbread May 16, 2021
    Ajikdevadas , via OnePlus 7 , May 16, 2021 :
    Recently while charging ,i am facing an issue.its not fast charging sometimes and its getting disconnected or something.its just like some loose contact
  2. akks
    KitKat May 16, 2021
    Best Answer
    akks , May 16, 2021 :
    Check for and clean the charging pin if any dust particles are there
  3. Ajikdevadas
    Dust is there inside the port.can u suggest and easier and good way for cleaning
  4. akks
    KitKat May 16, 2021
    Try using a clean dry brush or something similar.
    Njan anganeya cheyyaaru.
  5. Ajikdevadas
  6. akks
    KitKat May 16, 2021
  7. Ajikdevadas
  8. akks
    KitKat May 16, 2021
    Athaanu👍
  9. superplus
    Head Moderator Head Moderator May 16, 2021
    akks likes this.
