2
[Closed]Charging problem in OnePlus 5T
Thread Status:
Not open for further replies.
  1. N1525589403876
    Cupcake Feb 2, 2020
    N1525589403876 , Feb 2, 2020 :
    Recently I have charging problem in my One plus 5T .when I plug my phone in charge it gets 'charging' mode for few minutes later it changes to 'charging slowly' mode and sometimes it gets uncharged from charging can you guys help me to resolve this problem?
  2. #2
    Bilalazeem54 and N1525589403876 like this.
  3. kmrmadhusdan
    Cupcake Jul 2, 2020
    kmrmadhusdan , Jul 2, 2020 :
  4. kmrmadhusdan
    Cupcake Jul 2, 2020
  5. Madnezz4Ever , via OnePlus Community App , Jul 2, 2020 :
    Pleas read the post above yours as it was already mentioned what to do as it's a hardware issue.
    In order for rapid charge to work the cable must be inserted all the way
    Either you have lint in the port or there's a problem with the connection not holding.
    If it's lint, you can try cleaning the charging port with something small and no metallic.
    If it's the connection, you can try replacing the cable or charging port.
    Another member had success filing down some of the USB c part of the cable to shorting it some.
  6. Cervantes
    Lollipop Moderator Jul 2, 2020
    Cervantes , Jul 2, 2020 :
    Hi
    Question answered
    Please, check and use the battery thread for questions and comments, read the first post:
    https://forums.oneplus.com/threads/...our-stats-how-to-improve-battery-life.681970/
    Use the search engine before opening a new thread
    Thread closed
