90
[Closed][CM 14][Android][7.0/7.1] for OnePlus 2
Thread Status:
Not open for further replies.
  1. pppttl
    Gingerbread Sep 25, 2016
    pppttl , Sep 25, 2016 :
    Here you go.. You can see that in a game, the usage looks like this:
    Which clearly shows us, that those cores are working properly, they are just not turned on when we are doing light tasks. If you don't like this behavior, which is intentionally implemented like this, by design, just change the cpu governor and read the article above.
    luissalvador90 likes this.
  2. 7070
    Donut Sep 25, 2016
    7070 , Sep 25, 2016 :
    On
    Your latest download is volte working ?
  3. mido25
    Ice Cream Sandwich Sep 25, 2016
    mido25 , Sep 25, 2016 :
    Not workin for India but confirmed working in some carriers in Europe.
    Pranav Peddi likes this.
  4. sfksuperman
    Honeycomb Sep 25, 2016
    sfksuperman , Sep 25, 2016 :
    u r wlcm..but u didnt say ys or no abt uploading the roms???
  5. R@pt0r
  6. sparse Gupta
    Froyo Sep 25, 2016
    sparse Gupta , Sep 25, 2016 :
    it works but all apps are not compatible!!
    R@pt0r likes this.
  7. R@pt0r
    R@pt0r , Sep 25, 2016 :
    Oh. OK thanks... Also, which superSU should I flash? Xposed framework also?
  8. locxFIN
    KitKat Sep 25, 2016
    locxFIN , Sep 25, 2016 :
    No superSU, they break sensors. Xposed for N isn't available yet.
    R@pt0r likes this.
  9. sparse Gupta
    Froyo Sep 25, 2016
    as of now flashing supersu breaks all the sensors on cm14 so don't flash it.. xposed i don't know!!
    R@pt0r likes this.
  10. R@pt0r
    Oh. Hmm... So I'll have to enable the root in Dev options then?
    Also, it's OK if I flash Dolby Atmos and OOS Camera v3.5, right?
  11. eespanol
    Froyo Sep 25, 2016
  12. locxFIN
    KitKat Sep 25, 2016
    Yep, that should be fine. Just be aware that video recording doesn't work on OOS camera like it doesn't on CM either.
  13. mido25
    I'm not the dev of the rom. I just share the 'original works' from devs here who's not posting in XDA. So that users can find it easily.
  14. luissalvador90
    luissalvador90 , Sep 25, 2016 :
    Thanks ;)
  15. R@pt0r
    Thanks!!
    Update: Unable to flash Dolby but flashed OOS Cam...
    EDIT: Flashed the latest version if Dolby and it works...
    locxFIN likes this.
  16. Ranjithsmart
    Jelly Bean Sep 25, 2016
    Ranjithsmart , Sep 25, 2016 :
    22nd sep update from grark is official or unofficial ? what's about the regular updates?
  17. dpalejwala
  18. R@pt0r
    Charging time is higher that CM13. Or is it just mine? Taking around 3:30-4 hrs to full charge... While CM13 took around 2 hrs...
  19. Neerajms
    Eclair Sep 25, 2016
    Neerajms , Sep 25, 2016 :
    It's unofficial. You won't get an official build until OnePlus releases official sources.
  20. JoaoMota
    JoaoMota , Sep 25, 2016 :
    what is this program ?
