90
[Closed][CM 14][Android][7.0/7.1] for OnePlus 2
Thread Status:
Not open for further replies.
  1. sparse Gupta
    Froyo Sep 25, 2016
    sparse Gupta , Sep 25, 2016 :
    same as cm13 for me.... around 2 hrs!
  2. R@pt0r
    Gingerbread Sep 25, 2016
    R@pt0r , Sep 25, 2016 :
    Hmm... My charging current isn't going above 800mAh and sometimes drops down to even 200...
    Can't set custom values either as it's stock kernel...
  3. mido25
    Ice Cream Sandwich Sep 25, 2016
    mido25 , Sep 25, 2016 :
    Usemon you can find it in PS
    JoaoMota likes this.
  4. sourpatchmanx11
    Cupcake Sep 25, 2016
  5. EmmanuelMalho
    Donut Sep 25, 2016
    EmmanuelMalho , Sep 25, 2016 :
    Custom LEDs seem not to be working (can't set them - the screen where you set the custom color appears but it seems that it doesn't accept the value).
    EDIT: when trying to set up an application LED notification, the CM settings app crashes.
  6. ifkdui93
    ifkdui93 , Sep 25, 2016 :
    How is the battery life? And how long does it take to charge?. Can someone please do a full review
  7. pppttl
  8. pppttl
    pppttl , Sep 25, 2016 :
    Battery life is like CM13, much much better than OOS. Charging speed is around 1800 mAh with official charger, so it's under 2 hrs
  9. ifkdui93
    Any bugs?
  10. pppttl
    Video recording only works in google camera. And basically that's the only bigger bug. Grarak's 9-22 build is a daily driver material.
  11. sourpatchmanx11
    Cupcake Sep 26, 2016
  12. luissalvador90
    Honeycomb Sep 26, 2016
  13. ifkdui93
    Gingerbread Sep 26, 2016
    ifkdui93 , Sep 26, 2016 :
    How is the audio quality?for calls and music both?
  14. Ranjithsmart
    Jelly Bean Sep 26, 2016
    Ranjithsmart , Sep 26, 2016 :
    Yah but this unofficial build is awesome. What the difference between official and unofficial built?if I install cm13 can I upgrade to cm14 when they make cm 14 as official?
  15. R@pt0r
    R@pt0r , Sep 26, 2016 :
    Same here... Didn't find a solution yet. Hoping Grarak will fix it soon...
    The audio quality is quite good.
  16. mido25
    Ice Cream Sandwich Sep 26, 2016
    mido25 , Sep 26, 2016 :
    Use BetterBatteryStats and find out what's miscellaneous.
    When grarak pushes all his patches to cyanogen, they will review the code and accept. Once all his patches are Merged, we'll get official cyanogen.
    Of course you can upgrade. You just need to clean flash.
  17. chris_wds
    chris_wds , Sep 26, 2016 :
    Should we do a battery calibration to get a better battery life because I never knew if it really work
    For those who are asking for battery life I had like 4h SOT yesterday by watching YouTube videos all the journey but today I just won't on Facebook a bit and 5 min of YouTube and a bit of browsing and from 100℅ to 89℅ I had 28min SOT
    On Seraph's CM13 build I had 2h30 SOT so yes battery life is better on CM14
  18. EmmanuelMalho
    Donut Sep 26, 2016
    EmmanuelMalho , Sep 26, 2016 :
    Physical buttons backlight brightness not customizable. Same as the LEDs, screen's OK but it doesn't seem to accept the value.
  19. 7070
    Donut Sep 26, 2016
    7070 , Sep 26, 2016 :
    O in the latest one what's working b what is not working ??
  20. 7070
    Donut Sep 26, 2016
    Rea
