90
[Closed][CM 14][Android][7.0/7.1] for OnePlus 2
Thread Status:
Not open for further replies.
  1. EmmanuelMalho
    Donut Sep 26, 2016
    EmmanuelMalho , Sep 26, 2016 :
    Alarm clock doesn't accept music as a value for alarm ringer (it seems like there are a few setting values that aren't accepted, anyone spotted more?).
  2. Dcrew
    Froyo Sep 26, 2016
    Dcrew , Sep 26, 2016 :
    For some reason i am not able to download any app from play store . . Though internet is working with browser and i can download stuff through it . . But still downloading and updating through playstore is down . . . I have tried all obvious playstore setting . . From india reliance jio sim . . I know there is a thread abt it on one plus forum on grarak's build but i couldn't find a conclusion on it. . On 22/09build. Help would be appreciated . .
  3. pppttl
    Gingerbread Sep 26, 2016
    pppttl , Sep 26, 2016 :
    Which gapps did you flash?
  4. Dcrew
    Froyo Sep 26, 2016
    I flashed micro
  5. EmmanuelMalho
    Donut Sep 26, 2016
    I went with nano (had a constant google services crash in setup with aroma).
  6. R@pt0r
    R@pt0r , Sep 26, 2016 :
    Can we change the charging current using kernel auditor? My charging current is around 700mAh now. Sometimes goes down to even 200...
  7. mido25
    Ice Cream Sandwich Sep 26, 2016
    mido25 , Sep 26, 2016 :
    Vulkan is fully functional in latest build and CM upstream. Can be a daily driver.
  8. Dcrew
    Froyo Sep 26, 2016
    I'll try flashing pico
  9. mido25
    It can be set. Clear defaults of media service or alarm app and check again
    Cleared PS data and cache and tried? If that's not working, flash nano
    Make sure you're not using phone while charging
  10. Dcrew
    Froyo Sep 26, 2016
    I clean flashed the very first tym . .
  11. TunerCP
    Cupcake Sep 26, 2016
    TunerCP , Sep 26, 2016 :
    Am I the only one who can't use manual camera settings, like exposure time, manual focus, etc.? They don't work with manual camera either.
  12. Vishnugops
    Froyo Sep 26, 2016
  13. R@pt0r
    I don't unless it's to check Ampere or GSam to monitor the charging current.
    Yup. Around 4+ hrs for me...
  14. mido25
    For those who has charging issues, check the phone temperature while charging. There can be multiple reasons for charging time variations
    1. Thermal throttling on high temp
    2. Faulty charger/cable
    To confirm, I'd suggest switching ROMs.
  15. R@pt0r
    I'm using the original adapter but Belkin cable as the original one broke. Tried switching ROMS. Got 1400mAh on CM13...
    Temp comes around 38°C when charging. If I'm using it then, around 42°C. The low charging rate might be due to thermal throttling then. Would it be safe to turn off thermal throttling with Kernel Auditor?
  16. mido25
    Thermal throttling can be one of the reasons. But I don't have solution for that at least until custom kernel comes. Flash Ben's kernel and see if there's any improvements
  17. locxFIN
    KitKat Sep 26, 2016
    noquarter likes this.
  18. Greenflash
    Froyo Sep 26, 2016
    locxFIN likes this.
  19. locxFIN
    KitKat Sep 26, 2016
    locxFIN , Sep 26, 2016 :
    It was a leaked build, not properly tested. Mirrors are taken down, might as well edit the link out to not get people's hopes up.
  20. 93nikhilverma
    Donut Sep 26, 2016
