90
[Closed][CM 14][Android][7.0/7.1] for OnePlus 2
Thread Status:
Not open for further replies.
  1. Greenflash
    Froyo Sep 26, 2016
  2. mido25
    Ice Cream Sandwich Sep 26, 2016
  3. EmmanuelMalho
    Donut Sep 27, 2016
    EmmanuelMalho , Sep 27, 2016 :
    It worked, thanks!
  4. akhilsukh
    Froyo Sep 27, 2016
    akhilsukh , Sep 27, 2016 :
    mido25 , Can you post the most recent ones like the one for the 25th. I'm not sure if there is a reason you are not posting those?(such as they are not stable or such) and also specify who made( grarak, sreesha, etc)
  5. R@pt0r
    Gingerbread Sep 27, 2016
    R@pt0r , Sep 27, 2016 :
    Ben's Kernel? Is it good? I haven't heard of that. When I contacted Lord Boeffla, he said he'd release his kernel only after CM14 becomes official.
    I'll try Ben's then.
    Btw, is the phone supposed to be awake when in deep doze? Mine is awakeeven outside the maintenance windows:
  6. dpalejwala
    Honeycomb Sep 27, 2016
  7. acharyarev
    Ice Cream Sandwich Sep 27, 2016
  8. locxFIN
    KitKat Sep 27, 2016
    locxFIN , Sep 27, 2016 :
    Those guys are just using other people's work (namely Grarak's or Shreesha's), anyone could do it so there's no point listing them all. It's better to wait for the original dev to release them when he sees it's for the best.
    They are still quite experimental by nature so I would.
  9. mido25
    mido25 , Sep 27, 2016 :
    There are no public builds after the latest one from OP. The build other guy posted was leaked from AFH.
    Ben's kernel should have some thermal optimizations. Check it out once. Also heard that his version of Cm14 comes with uber and his kernel. Worth a try. Just see if it solves your problems.
    He's from Germany. No jio won't work.
    R@pt0r likes this.
  10. acharyarev
    acharyarev , Sep 27, 2016 :
    Lol.:p can imagine your frustration seeing posts on jio network. Anyways thanks.
  11. acharyarev
    There are plenty of cm14 ROMs from various devs now. Last one i found was build dated 26th September from @hunterbruhh
  12. Rushabh Gohel
    Jelly Bean Sep 27, 2016
    coolrevi likes this.
  13. acharyarev
    Lol, thanks. Decided to do that to avoid same old posts on volte:p
    Rushabh Gohel likes this.
  14. mido25
    See, everyone is using Grarak's trees and there are absolutely no difference in those builds. Few noticeable differences are Ben uses his same kernel on his cm14 and hunter has OMS commits which will help themers. As both of them have xda threads, I don't think that needs to be featured here.
    locxFIN and coolrevi like this.
  15. sultan45
    Cupcake Sep 27, 2016
  16. mido25
    Robson likes this.
  17. R@pt0r
    I suggest you add that fact to the first post. O/w ppl are gonna keep on asking...
  18. R@pt0r
    My screen doesn't turn off while calling. Anybody else notice that?
    Oh and after you open emergency details on the lock screen, the FPS acts as the home button for a few tries before it unlocks....
  19. spencer1620
    spencer1620 , Sep 27, 2016 :
    Shout it a bit louder so they hear you.
    "IT'S NOT WORKING!!!"
  20. spencer1620
    Screen off during calls works here did you flash supersu ?
