90
[Closed][CM 14][Android][7.0/7.1] for OnePlus 2
Thread Status:
Not open for further replies.
  1. acharyarev
    Ice Cream Sandwich Sep 27, 2016
    acharyarev , Sep 27, 2016 :
    No point look at people still asking exact same question which was answered just 2 post above.
    spencer1620 and R@pt0r like this.
  2. R@pt0r
    Gingerbread Sep 27, 2016
    R@pt0r , Sep 27, 2016 :
    Oh. That's why the sensor broke... Mido had warned me about that but I flashed SU before his reply... So, dirty flashing the ROM again should solve it, right?
  3. mido25
    mido25 , Sep 27, 2016 :
    Yeah that'd do the trick. SU breaks sensors atm. Heard shreesha is working on it.
    christopher78 and R@pt0r like this.
  4. tkarthiknaidu
    Cupcake Sep 27, 2016
    tkarthiknaidu , Sep 27, 2016 :
    Guys, This is my First post here in this thread.
    I am planning to root my OP2 to CM14>Nougat OS.
    i just want to know, Have someone tested it on OP2 and howz the battery performance other stuffs.
  5. pppttl
    pppttl , Sep 27, 2016 :
    Just read the posts above.
    nitin_g3, osd22, R@pt0r and 2 others like this.
  6. ponczoszek
    ponczoszek , Sep 27, 2016 :
    Take 5 minutes of your time and read few pages back - its all there - answers for your questions.
    R@pt0r likes this.
  7. R@pt0r
    About rooting your OP2, there's a great thread by @Funk Wizard Try that...
    As for details about CM14 I'd second @ponczoszek 's advice.
    Funk Wizard likes this.
  8. chris_wds
    Honeycomb Sep 27, 2016
    chris_wds , Sep 27, 2016 :
    No solution for the moment?
  9. R@pt0r
    Obviously no except by not flashing SU...
  10. R@pt0r
    Another bug I found: In settings, if you search for visualiser and click the display visualiser option, the app crashes. Can anyone second this observation?
  11. EmmanuelMalho
    Donut Sep 27, 2016
    EmmanuelMalho , Sep 27, 2016 :
    It worked normally here, visualizer turned ON/OFF smoothly.
  12. spencer1620
    spencer1620 , Sep 27, 2016 :
    That's odd I tried on mine and it f/c
    R@pt0r likes this.
  13. ponczoszek
    Here it fc's also - I dirty flashed 2 builds before, I guess some of the functions require clean flash.
    R@pt0r likes this.
  14. R@pt0r
    Did you clean flash or dirty flash?
    Might be...
  15. inflames91
    Donut Sep 27, 2016
    inflames91 , Sep 27, 2016 :
    Hey I usually use the hardware buttons and I'm having a slight issue with the home button.
    I use the double tap feature to turn off the screen and the home button doesn't function for a second. Works after I press it once again.
    Anyone else facing this?
    (I've clean flashed)
  16. R@pt0r
    The button doesn't function instantly after turning off the screen? Check your screen lock time. Might be the FPS kicks in thinking your phone has locked...
  17. R@pt0r
    An additional observation to my earlier post on Settings f/c:
    The Settings closes whenever I try to open the cog wheel next to the Screen Lock option in Security. I guess the power button instantly locks, visualiser, etc are in that section as opening those f/c the app.
  18. inflames91
    Donut Sep 27, 2016
    Hey thanks for the info.
    I'll elaborate a little further.
    This doesn't necessarily have to do with turning off the screen.
    It just freezes randomly in between while using the phone as well.
    Tapping the button a second time solves the issue.
    I've checked on CM13 and there is no such issue on that ROM.
  19. R@pt0r
    I usually get that when unlocking the phone.... Guess it's a bug...
  20. R@pt0r
    Do you use a pattern or a PIN?
    Do you guys use a PIN?
    I'm asking coz I found a solution. Change the Screen Lock to Pattern and then try to access that menu. It worked for me. Could you second this finding?
    spencer1620 likes this.
