90
[Closed][CM 14][Android][7.0/7.1] for OnePlus 2
Thread Status:
Not open for further replies.
  1. spencer1620
    Ice Cream Sandwich Sep 27, 2016
    spencer1620 , Sep 27, 2016 :
    Yes I do have a pin as secondary unlock changed it to pattern and problem solved, Well done thanks
    R@pt0r likes this.
  2. shailinder
    Froyo Sep 27, 2016
    shailinder , Sep 27, 2016 :
    Hi Guys,
    Need a quick advice. I have been using CM13 from quite some time and trying to upgrade to cm14 aka nougat. But the issue I am facing is after flashing...after punching in WIFI user name and password...connect tab is not getting enabled to move forwarded. I have tried configuring it on data network but there I am getting an error as problem comunicting with Google servers.
    I have tried with GAPPS - PACO, Nano, Micro etc hoping that it would work with something but it is not...
    What could be the reason ? and probable solution...
  3. R@pt0r
    Gingerbread Sep 27, 2016
    R@pt0r , Sep 27, 2016 :
    The problem might be with the package. You're using Open Gapps?
    There are a few things you could try:
    1. Try a clean flash
    2. Try to connect to another network
    3. Try another Gapps
  4. shailinder
    Froyo Sep 27, 2016
    I am using the same source of Gapps. Which I used to flash cm13 earlier. I have used following sites for the Gapps:
    http://opengapps.org/?download=true&arch=arm64&api=7.0&variant=pico
    Not sure if there are any active and heavily used link for Gapps links. :)
    Moreover, if I go for clean flash. How would I recover backup if something goes wrong. Or backup would remain there ?
  5. R@pt0r
  6. shailinder
    Froyo Sep 27, 2016
    Nah...other network is pending. Would try today or tomorrow but unable to digest that because of wifi network. I am unable to click on CONNECT or it is not enabled :(
  7. locxFIN
    KitKat Sep 27, 2016
    locxFIN , Sep 27, 2016 :
    Which build? I heard wifi was broken on some builds when they complied from broken CM sources. Use Grarak's or Shreesha's to be safe.
  8. mido25
    mido25 , Sep 27, 2016 :
    Guys when you report bugs, please mention who's build and the build date. It'll help us to help you in troubleshooting.
    locxFIN likes this.
  9. shailinder
    Froyo Sep 27, 2016
    Guys, Deleted all the internal files and got to a point that there wasn't anything on my phone. Not even a OS :)
    In fact everything from the mobile...and now copy pasting, cm 14 + Gapps nano pack...to internal memory.
  10. shailinder
    Froyo Sep 27, 2016
  11. locxFIN
    KitKat Sep 27, 2016
    Don't wipe internal storage when clean flashing. Next time you'll know :)
  12. EmmanuelMalho
    Donut Sep 27, 2016
    EmmanuelMalho , Sep 27, 2016 :
    I've clean flashed and I use fingerprint/pattern.
  13. shailinder
    Froyo Sep 27, 2016
    Wow it took good 5 mins to reboot and now WIFI password punched in...and it took the password.
    So not sure whether new network did work or clean flashed. Let me complete the set up and confirm.
  14. Mohamm3d_adam
    Froyo Sep 27, 2016
    Mohamm3d_adam , Sep 27, 2016 :
    Anyone facing duplicate contacts issue ? My normal and WhatsApp contacts have been separated and I should probably go to each contact and use the link option.
    Any solution how to fix this? Tried clearing data and cache of contacts storage but still the same :/ I'm using 22nd build.
  15. shailinder
    Froyo Sep 27, 2016
    Alright. So everything seems to be working but camera and that too video.
    I am using Grarak's version cm-14.0-20160922-UNOFFICIAL-oneplus2.zip
    Thanks guys. Will keep you posted if I encounter anything new or buggy. Or go back to CM13 if these bugs are too much to handle at this point in time.
    Take Care n good night from India :)
    spencer1620 likes this.
  16. mido25
    Congratulations on your brand-new phone
    christopher78 likes this.
  17. Dcrew
    Froyo Sep 27, 2016
    Dcrew , Sep 27, 2016 :
    There is no problem with rom . Maybe you have multiple contact backups on different locations like google sync n sim or phone . . . Try selecting perticular contact view from contact app . . . Or if u still have problem there are many apps on playstore to remove duplicate contacts use one of those . .
    Mohamm3d_adam likes this.
  18. Dcrew
    Froyo Sep 27, 2016
  19. mido25
    I think you forgot to pay their salary for this week that's why you're not getting any 'tentative dates'
  20. Dcrew
    Froyo Sep 27, 2016
    Hey i was not being rude... Being a software developer myself i know how hard this work is . . With all respect to grarak (as i am only following his rom) my comment was just out of excitement since i am downloading all of his cm14 roms the very day he posts it . . . Peace ✌️
