8
[CLOSED] Delay in response after call disconnect
Thread Status:
Not open for further replies.
  1. hari ram prasath
    Eclair Jan 1, 2019
    hari ram prasath , Jan 1, 2019 :
    Team
    there is a delay in response after call disconnect screen display response is slow after call disconnect pls solve the issue
  2. M1557831472091
    Cupcake Jun 5, 2019
    M1557831472091 , Jun 5, 2019 :
    i observed same in my 6T. Not sure of other end call is still active till it terminates?. Need quick attention of this issue if observed in wider group of 6T users. Thank you
    Nilesh7113 likes this.
  3. Waveform Modifier
    Marshmallow Jun 5, 2019
    Waveform Modifier , Jun 5, 2019 :
    Wrong forum
  4. DavidMeshach
    Donut Aug 10, 2019
    DavidMeshach , Aug 10, 2019 :
    same problem I'm also facing in one plus 6
  5. Waveform Modifier
    Marshmallow Aug 11, 2019
  6. aashishv12
    Cupcake Aug 31, 2019
    aashishv12 , Aug 31, 2019 :
    When I disconnect a mobile call from my OnePlus 7, the screen lags and I still see the ongoing call for about 5 seconds.
    omprakasjha likes this.
  7. qmpzal
    Cupcake Jan 13, 2020
    qmpzal , Jan 13, 2020 :
    I would like to report the same issue on my OP 5. The ongoing call lasts for additional 3-5 seconds and I don't know if it is just a display problem or the call it's still active. This is active after the last update. I will try to clean cache from recovery but maybe somebody knows what's causing it... Thanks...
    LE: clearing cache does nothing, so the issue is still present...
  8. mdevinderdahiya
    B1579363210347 likes this.
  9. itsashis4u
    Cupcake Jan 17, 2020
  10. sumukhks
  11. Abhishesh_Sigdel
    Cupcake Jan 18, 2020
  12. B1579363210347
  13. Q1572954670658
    Cupcake Jan 20, 2020
  14. Abhyuday Vijay
    Cupcake Jan 21, 2020
  15. letizh
    Cupcake Jan 22, 2020
  16. gaster
    Lollipop Moderator Jan 22, 2020
    gaster , Jan 22, 2020 :
    Hi friend. If you are facing any issues with the latest OOS update, you could post your concerns to the already official existing thread here https://forums.oneplus.com/threads/oxygenos-9-0-10-ota-for-the-oneplus-5-and-oneplus-5t.1155523/ or even submit any bug report you found in the feedback section here https://forums.oneplus.com/feedback/. Please next time use the search function before posting a new thread. I am closing now this one. Thank you!
