2
[Closed] Demand for Oxygen OS 12 for OnePlus 6 because of faulty Buggy Oxygen OS 11.1.1.1 via OnePlus 6
Thread Status:
Not open for further replies.
  1. P1568478305754
    Cupcake Nov 28, 2021
    arvindllb16 and mohitrajput901 like this.
  2. Royal_RJ
    Ice Cream Sandwich Nov 28, 2021
    Royal_RJ , via OnePlus 6 , Nov 28, 2021 :
    A11 is not performing good yet and here developers are not able to fix it's bug's and issue's. They just rollout A11 for OnePlus 6 because they need to get rid of this series.
    P1568478305754 likes this.
  3. drl431
    Junior Moderator, Community Hero 2020 Junior Moderator Nov 28, 2021
    drl431 , via OnePlus 6 , Nov 28, 2021 :
    Android 11 works great on my OP6, especially with getting cell service in large buildings. Adaptive brightness is still flaky, but its never worked well. Anyway, the OP6/6T are going to be EOL very soon and begging for Android 12 won't change that.
  4. A1594910915738
    Honeycomb Nov 28, 2021
  5. kouzelnik3
    kouzelnik3 , Nov 28, 2021 :
    That's the update which is probably supposed to force you to buy a new device. This A11 update is just crippled in few ways. Or you can perform a factory reset to solve majority of bugs. Or install Custom ROM - up to you.
  6. WonMinus
    Eclair Nov 29, 2021
    E1529821422497 and KluGe like this.
  7. kouzelnik3
    Ice Cream Sandwich Nov 29, 2021
    kouzelnik3 , Nov 29, 2021 :
    It will be I guess :D
  8. FaleshC
    KitKat Nov 29, 2021
    drl431, LegolasX and otto2 like this.
  9. Y1531508033555
    Froyo Nov 30, 2021
    Y1531508033555 , via OnePlus 6 , Nov 30, 2021 :
    Do a fresh install of 11.1.1.1 and it will work smooth, my OP6 had performance and battery backup issues when it was updated to 11.1.1.1 through automatic updates. Those are gone now.
    P1568478305754 and drl431 like this.
  10. jontalk
    Ice Cream Sandwich Nov 30, 2021
    jontalk , Nov 30, 2021 :
    I suspect the issues being experienced are related to third party apps rather than the update. You might think about disabling or removing them, clear the system cache and see if it helps. Keep in mind the Dev team doesn't test updates on phones with social media, gaming or utility apps that might interfere
  11. #12
    otto2 likes this.
  12. strokejuan
    Donut Dec 3, 2021
  13. Creaco
    Cupcake Dec 3, 2021
    Creaco , via OnePlus 6T , Dec 3, 2021 :
    We won't and never will be getting any android 12 updates. What we will be getting are bug fixes and security updates if necessary.
    The device has reached its eol
  14. Gav_W86
    Moderator Moderator Dec 3, 2021
    Gav_W86 , Dec 3, 2021 :
    as it says above, and in the official post. OP6 series is end of life for major updates, 12 won't be coming for it.
    drl431 likes this.
