2
[CLOSED] does anyobe have trouble pairing oneplus 6 with Bluetooth headphones?
Thread Status:
Not open for further replies.
  1. mj333
    Cupcake Jun 1, 2018
    mj333 , Jun 1, 2018 :
    see title. I have tried few Bluetooth headphone, but the phone can't find any of my headphones. I have no problem with my old phone.
    B1570029213173 and Shanghorpade like this.
  2. ap0f1s387
    Cupcake Jun 2, 2018
    ap0f1s387 , Jun 2, 2018 :
    I have to problem with searching bluetooth devices, but i solved the problem. You must on show bluetooth devices without a name in developer options.
    Laaxev likes this.
  3. Gav_W86
    Starting Point Expert Jun 3, 2018
    Gav_W86 , Jun 3, 2018 :
    I've paired with two sets of BT headphones and my car without issue.
    What headset?
    also, if transferring from previous phone, most headsets have limited pairing slots, you might need to clear the headset.
  4. mj333
    Cupcake Jun 3, 2018
  5. dom_sosa7
    Cupcake Jun 11, 2018
    dom_sosa7 , Jun 11, 2018 :
    i have a pair of jlab wirless headphones. i have bluetooth on, on my one plus 6. but nothing comes up when searching for them.. please help
  6. mj333
    mj333 , Jun 11, 2018 :
    I tried a few pairs , some connect fine, some won't be detected. I just use one that works.
  7. IdaKorkiakoski
  8. Blokeinlondon
    Blokeinlondon , Jun 11, 2018 :
    I have had no issue with headphones or earphones but I cannot get me Wahoo Element cycling computer to connect to the OnePlus 6! Its really frustrating as it was working with my OnePlus 2 no problem. Wahoo are looking into the issue but they are as baffled as I am right now. I thought that I would add something here to see if anyone else has the same thing with the onePlus 6/ Wahoo Element combination. Thanks
  9. Laaxev
    Cupcake Jun 25, 2018
    Laaxev , Jun 25, 2018 :
    Thank you so much it worked!!!!
  10. d0h15
    Cupcake Jul 29, 2018
    d0h15 , Jul 29, 2018 :
    I have the same issue. Have you found a solution for it in the meantime?
  11. altr_dev
    Cupcake Aug 14, 2018
    altr_dev , Aug 14, 2018 :
    I have the issue with qr code procedure!
  12. Gunth1
    Cupcake Aug 22, 2018
    Gunth1 , Aug 22, 2018 :
    I have it to.
    It's very frustrated.
    Every other phone I have works fine
  13. altr_dev
    altr_dev , Aug 22, 2018 :
    Incredible, I resolved the issue.
    I rotated the phone horizontally and I moved away enough from the bolt. Scan ok and now I use the bolt.
    I tried to use a third-party app for QR code and I noticed a similar problem. I recommend trying to understand the distance to which OPO6 responds and then apply to the bolt qr code procedure.
  14. Gunth1
    Thx man,it worked
    altr_dev likes this.
  15. altr_dev
    Gunth1 likes this.
  16. vilmantasr
    Donut Aug 22, 2018
  17. easytaxontario2018
    Cupcake Oct 26, 2018
    easytaxontario2018 , Oct 26, 2018 :
    I have had trouble with all Bluetooth pairing since purchasing my OnePlus 6. Until I received PIE I could not call using my Bluetooth car system as the cell would ring through handsfree but when someone answered it switched back to handset only.
    Today, after speaking with a service representative who was wishing me to to a full system upgrade, risking the loss of all my business notes saved to the phone, I was given the advise to try and clear the earbud device of its connection information with my previous Samsung phone.
    I went to the Plantronics website and learned how to "pair to a different phone" and I worked!
    My headset is finally connected to my OP6!
    Please consider this action for your headsets
    Be well
    Suzanne
  18. OALEXANDER
    Indian POC Assistant Head Moderator Feb 5, 2019
