[CLOSED] First 10% battery drain is very fast!
Thread Status:
Not open for further replies.
  1. tamsajama
    Donut Jul 13, 2015
    tamsajama , Jul 13, 2015 :
    I'm currently on CM 12.0 YNG1TAS2I3.
    I can't figure out why my initial 10% of battery I.e. From 100 to 90 drains very fast. I've tried different roms like exodus, resurrection, carbon, 12.1 nighty, etc... But more or less this problem persists.
    Anyone else familiar with this?
    Can you provide a solution please.
    Thanks in advance. Screenshot_2015-07-13-22-07-38.png Screenshot_2015-07-13-22-07-57.png
  2. royz0r
    Jelly Bean Jul 13, 2015
    DaxNagtegaal and tamsajama like this.
  3. championspike
    Ice Cream Sandwich Jul 13, 2015
  4. tamsajama
    Donut Jul 14, 2015
    tamsajama , Jul 14, 2015 :
    Ok Thank You.
    Did you experience this ?
    royz0r likes this.
  5. tamsajama
    Donut Jul 14, 2015
    I didn't find any forum relating this topic.
    Can you provide a link please.
    eknes likes this.
  6. loulouboy
    Ice Cream Sandwich Jul 14, 2015
    loulouboy , Jul 14, 2015 :
    Odd. It's the complete opposite for me. Probably because I don't have all my apps running in the background(since I kill them all before I charge it).
  7. ninjasumit
    ninjasumit , Jul 14, 2015 :
    35 minutes of SOT from 100% to 90%. I don't see how its very fast. Its pretty normal. What do you expect? 1 hour SOT in 10% drain?
    jnh010 and Dr. Indest like this.
  8. Dr. Indest
    Lollipop Jul 14, 2015
    Dr. Indest , Jul 14, 2015 :
    This is typical with a non-modified Lolipop version. Usally you can expect to get 1 hour SOT per 20%.
    If you edit things, you will get longer battery. Look at my sig.
  9. Dr. Indest
    ;) I do.... One day though.... one day....
    ninjasumit likes this.
  10. iphoneuser019
    Jelly Bean Jul 14, 2015
  11. royz0r
    royz0r , Jul 14, 2015 :
    Yes
  12. bmark240
    bmark240 , Jul 14, 2015 :
    Indest has some good knowledge of battery saving. He will teach you about Greenify, Xposed frameworks and wakelocks.
    Start with Better Battery stats to see what is eating away at your battery and I'm sure that if you stop some non essential services with advice from Indest you will have a better battery life. Remember, when you are charging your phone. It puts some, not all services into temporary hibernation. When you unplug your phone from charging, it has to restart all those running services again and this will 'eat' your battery.
    championspike likes this.
  13. championspike
  14. DanCtoo
    Honeycomb Jul 14, 2015
  15. gjegadeesh
    gjegadeesh , Jul 14, 2015 :
    it's quite normal i think. try to keep idle for 1hr after charging 100%, if it's drain the battery than you can go for tweaks. better to do the battery calibration.
  16. redleema
    KitKat Jul 14, 2015
    redleema , Jul 14, 2015 :
    Not a good answer. The search results for battery drain is too massive to seive through for this query.
    @tamsajama can you provide a screenshot of the app usage/battery after the initial drain as this could indicate the main culprits.
  17. championspike
  18. DaxNagtegaal
    Marshmallow Jul 14, 2015
    DaxNagtegaal , Jul 14, 2015 :
    I haven't killed any apps in like 3 days lol
  19. EvoGaming21
    Eclair Jul 14, 2015
  20. loulouboy
    DaxNagtegaal likes this.
