[CLOSED] flash disabled due to low battery is just ****
Thread Status:
Not open for further replies.
  1. mandy5951
    Eclair Jan 15, 2018
    mandy5951 , Jan 15, 2018 :
    Oneplus folks just tell me what is the use of that 1 to 15% battery level when I just can't capture the moment of my life due to flash disabled to preserve battery!!?
    Huh?
    I might be camping where there is no network coverage. By chance my battery is 15% and less in the evening. So what? I can't just use flash to capture that moment! It's ridiculous.
    marxspawn likes this.
  2. AlexandreP
    Honeycomb Jan 16, 2018
    AlexandreP , Jan 16, 2018 :
    And if you try to manually re-enable flash when you're in this situation, does it work?
    (Really asking, never tried myself. Maybe it's just a default setting to help prevent battery drain, but can be re-enabled if the user confirms its intention.)
  3. F_Terence_Quah_gSCv
    Ice Cream Sandwich Jan 16, 2018
  4. F_Terence_Quah_gSCv
    F_Terence_Quah_gSCv , Jan 16, 2018 :
    on oreo. the battery saver mode is now a much harsher version than in nougat (previously in nougat u can on it 24/7
    as it's a light version of battery saving mode)
    however oreo ones is a heavy saving mode(not to the extreme saving airplane style but half there. it really do disable quite a lot of things).
    I tone it down to 10% only auto on.
  5. InaM__
    Froyo Jan 19, 2018
    InaM__ , Jan 19, 2018 :
    in the low battery it is common to turn off the flash in all devices not only 1 + every mobile brand do the same and you have to maintain the charging or else turn off the power saving mode maybe sometimes power saving mode disable and does not start the flashlight in the low battery
  6. mandy5951
    Eclair Jun 24, 2019
    mandy5951 , Jun 24, 2019 :
    No, not in Xiaomi.
  7. pablofg1978
    Spanish POC Assistant Head Moderator Jun 24, 2019
