[CLOSED] Gear icon missing One Plus 9 Pro via OnePlus 9 Pro
Thread Status:
Not open for further replies.
  1. B1608811714745
    Cupcake Nov 30, 2021
    B1608811714745 , via OnePlus 9 Pro , Nov 30, 2021 :
    Hello. After i downloaded Oxygen os Beta 1 and installed it the gear icon and local update is gone missing. I downloaded the incremental open beta 2 and was about to install but i can't find the gear in system updates or local update ? Please help me . I will post some screenshots. I am from Norway and i selected EU files. I can't roll back to stock either. Are there some options to do this with a computer ? Sorry my bad English writing
  2. Aaron2017
    General Support Expert Award 2021 Nov 30, 2021
    Aaron2017 , Nov 30, 2021 :
    You need to install this APK to get the system updater with local upgrade option (click on "APK" in the quote)
    Delete the .zip part at the end to install it and after installing you should find it as an app in your app drawer.
    G_plusone and Caomhin like this.
  3. B_Wrath
    Junior Moderator Junior Moderator Nov 30, 2021
    Caomhin, Chris1223 and Dresa91 like this.
