220
[CLOSED][GUIDE] How to Unroot your OnePlus 3 / 3T and go back completely to stock
Thread Status:
Not open for further replies.
  1. G_Sam_Saju_sqZs Donut Apr 4, 2018
    G_Sam_Saju_sqZs, Apr 4, 2018 :
    Thanks for the reply but I have a question - there any other way without using the tool? And If there isn't are you able to give me a link?
  2. Deactivated User Apr 5, 2018
  3. imakul8 Cupcake Apr 19, 2018
    Deactivated User likes this.
  4. Deactivated User Apr 23, 2018
  5. S_T_A_R Gingerbread Apr 27, 2018
    S_T_A_R, Apr 27, 2018 :
    I have an issues after unroot and lock bootloader, when I reboot my OP3T there is a screen showing start in 5 sec. Etc.
    How can i remove this.
  6. Paschfire Jelly Bean Apr 28, 2018
    Paschfire, Apr 28, 2018 :
    All depends on what the screen message says.
  7. A.Broken.Star Cupcake Apr 30, 2018
    A.Broken.Star, Apr 30, 2018 :
    I'm currently running Android N (7.0) Resurrection Remix ROM. Should i download Stock Oreo or Nougat ROM ? I want to be on open beta OOS (dont care if its Android O or N).
  8. Deactivated User May 5, 2018
  9. lkosova Ice Cream Sandwich May 7, 2018
    lkosova, May 7, 2018 :
    Hi, thx for the great thread. I bought 2 phones when op3 came out Mine I learned to update, sideload etc with yours and others help. No problem...
    My son rooted his and used trwp He is still on 3.1.2 (never had any issues). He wants to update to 5.0.1 Android 8.0. He has tried and downloaded the update after taking off the root and the phone seems to be boot into trwp.
    Does he still need to follow the instructions on the first page since he is using trwp? If trwp is blocking the update is there a way to remove trwp, update, then put trwp back on? Or another solution leaving trwp. (I have limited trwp knowledge even after looking it up)
    I guess I am just asking for the best solution with my limited knowledge I have searched but was confused since he is on 3.1.2 why would he roll back to the same?
    Thanks again in advance.
  10. St0ne_ Cupcake May 10, 2018
    St0ne_, May 10, 2018 :
    It says "Open Beta 33 (for the OnePlus 3)", but is it also working if i have Open Beta 35 installed?
    EDIT: It worked 100% fine, thank you very much for the tutorial. I can confirm this 100% works with Open Beta 35.
  11. Bobbie63 Lollipop May 10, 2018
    Bobbie63, May 10, 2018 :
    @Sun90, any chance you are able to help out on this?
  12. Deactivated User May 12, 2018
    Bobbie63 likes this.
  13. lkosova Ice Cream Sandwich May 12, 2018
    lkosova, May 12, 2018 :
    Hi, good to see you here. Yes I have some confusion but just want to make sure If I am still going back to stock since I think my son is still on stock but with trwp. My post is two above.
    Last question... Since you have been great for the forum and a advanced user.... May I ask what rom you are going to? Just curious since I will be looking at some point.
    All the best and thx for all your help here.
  14. Deactivated User May 12, 2018
  15. lkosova Ice Cream Sandwich May 12, 2018
    So then with this question..... Above..... Just completely go back and use the guide correct.,since he has trwp....??? Sorry that is where I get confused.
  16. Deactivated User May 12, 2018
  17. lkosova Ice Cream Sandwich May 12, 2018
    That is what I thought He showed me his phone says it was unrooted when he did something but just checking Will follow the guide Again all the best and hope to see you back at some point Op3 is great for my use and the hardware is solid. I will just play around with roms and see what I like
    Thx for everything you did for the forum I will miss your remarks...... Lol :cool:
    Deactivated User and Bobbie63 like this.
  18. SgtIcetea Honeycomb May 24, 2018
    SgtIcetea, May 24, 2018 :
    How do I fix the dm-verity message? I thought following this guide would also get rid of it but it didn't is there a faster way than re-rooting, installing twrp and following the guides that flash older firmware?
  19. laupuy Honeycomb May 24, 2018
    SgtIcetea likes this.
  20. SgtIcetea Honeycomb May 24, 2018
    laupuy likes this.
