(closed) Hanging and battery issues via OnePlus 7 Pro
Thread Status:
Not open for further replies.
  1. P1562046881821
    Cupcake Jun 17, 2021
  2. Artemus.
    Community Hero 2020 Jun 17, 2021
    Artemus. , Jun 17, 2021 :
    When did you last wipe your phone?
  3. Z1612187578731
    Gingerbread Jun 17, 2021
  4. Rana0003
    Gingerbread Jun 18, 2021
  5. Liehjan
    Marshmallow Jun 19, 2021
    Liehjan , Jun 19, 2021 :
    You could go back to A10 or do a factory reset on A11... Not much else that can be done.
    Artemus. likes this.
  6. vinay11singh
    Honeycomb Jun 20, 2021
  7. Abhi_RightNow
    Froyo Jun 20, 2021
  8. vinay11singh
    vinay11singh , via OnePlus 7 Pro , Jun 20, 2021 :
    Switch off the phone and switch on by pressing down volume key and power key simultaneously. Then enter password and select language of you choice. After that you can see there is the option of wipe cache select it and follow on screen instructions.
  9. Ankita_S.
    OnePlus Bug Hunter Staff Member Jun 20, 2021
    Ankita_S. , Jun 20, 2021 :
    We'll definitely work on the issue reported and we'll do our best to help you. We've got in touch with you via direct message. Looking forward for your response!
    Regards,
    Ankita
  10. Abhi_RightNow
    Froyo Jun 21, 2021
    Abhi_RightNow , via OnePlus 7 Pro , Jun 21, 2021 :
    Thank you
  11. Abhi_RightNow
    Froyo Jun 21, 2021
  12. vinay11singh
    Honeycomb Jun 21, 2021
  13. keithnyc
    Moderator Moderator Jun 21, 2021
