[CLOSED] Headphone jack error
Thread Status:
Not open for further replies.
  1. J1513095112497
    Donut Jun 24, 2019
    J1513095112497 , Jun 24, 2019 :
    Recently I have been getting problems with my headphone jack no matter which headphones I use it keeps getting popped out. Any solution or go for a new one, if yes then please provide the cost of replacement and thanks in advance for your suggestions
  2. Jacek Pecka
    Ice Cream Sandwich Jun 24, 2019
    J1513095112497 likes this.
  3. Madnezz4Ever
    Jelly Bean Jun 24, 2019
    Madnezz4Ever , Jun 24, 2019 :
    If it keeps popping out, then one of the metal pins could be bent in side the jack and needs to be replaced.
    Not sure how much they charge to fix it, but you can find the part on Amazon or eBay if you want to do it yourself.
    It's a ribbon cable that contains both the charging port and headphones jack. Make sure to get tools for it if you do it yourself.
  4. Waveform Modifier
    Marshmallow Jun 24, 2019
    Waveform Modifier , Jun 24, 2019 :
    I thought the headphone jack is a metal ball instead of a pin.
  5. J1513095112497
    Donut Jun 24, 2019
    tried that too but no change
  6. J1513095112497
    Donut Jun 24, 2019
    sure bro thanks for your advice
  7. Meherbanali
    Froyo Jun 25, 2019
    Meherbanali , Jun 25, 2019 :
    facing the same problem. let me know when you get it fixed.
    My problem is a month old so i bought a TYPE-C Headphone.
  8. J1513095112497
    Donut Jun 28, 2019
    J1513095112497 , Jun 28, 2019 :
    thinking to replace it
    Meherbanali likes this.
  9. Meherbanali
    Froyo Jun 28, 2019
  10. J1513095112497
    Donut Jun 28, 2019
  11. Meherbanali
    Froyo Jun 28, 2019
    Meherbanali , Jun 28, 2019 :
    No, But update here when you get it repaired. I will update as soon as i get it repaired.
  12. J1513095112497
    Donut Jun 28, 2019
    sure bro
  13. J1513095112497
    Donut Jul 2, 2019
    J1513095112497 , Jul 2, 2019 :
    so yesterday night I discovered that so much lint is present in the headphone jack so u check whether lint is present in the headphone jack even I thought there wasn't but when I started to insert my safety pin and pulled it out I found so much of lint which caused the jack to pop out so simple use a safety pin and try to dug in u will be happy to find lint or better luck on changing the jack [e]1f602[/e]
  14. Meherbanali
    Froyo Jul 6, 2019
    Meherbanali , Jul 6, 2019 :
    Hey Man,
    Problem is solved thanks, but i used brush instead. worked well
  15. J1513095112497
    Donut Jul 6, 2019
    J1513095112497 , Jul 6, 2019 :
    good to hear
  16. gaster
    Moderator Moderator Jul 8, 2019
    gaster , Jul 8, 2019 :
    Hi friends. As much as the case is solved according to your answers, I am closing now this thread. For further assistance if anything's wrong, please don't hesitate to contact the customer support live chat here and hit on the chat with us button. Thanks!
