33
[CLOSED]Issue solver (battery drain etc.) - please try before you make another battery thread
Does uninstalling FB / messenger app solve your battery drain issues
Poll closed Jan 17, 2017.
  1. yes, of course!
    54.9%
  2. no, obvoiusly...
    22.0%
  3. I want Carl Pei to solve my phone issue personally (because why not)
    23.2%
Thread Status:
Not open for further replies.
  1. iNtEnSePL
    KitKat Jan 10, 2017
    iNtEnSePL , Jan 10, 2017 :
    IF
    you have issues with battery drain, that came out of the blue, you updated to OOS 4.0.0 or 4.0.1 or 4.0.x (futureproof thread ;)), and don't know what to do
    THEN
    uninstall Facebook app, FB messenger or anything FB.
    AND
    check if that helped
    There are numerous users reporting that they have the issue regardless of OS version, or the previous OS version they updated from. And uninstalling solved the problem. Heck, they even report that front cam gives blurry pictures in these apps, while working just fine outside of FB app.
    So please, try that before you post anything. If that doesn't help... (sh**, I didn't think of it) - just... uninstall everything :) battery will be happy :D
    EDIT 11.01.2016 10:00 AM: FB said it's indeed their fault, probably solved by now...: https://twitter.com/davidmarcus/status/818908229585420288
  2. theunintelligible
    Eclair Jan 10, 2017
    theunintelligible , Jan 10, 2017 :
    Tried that. phone is still overheating an battery drained more than 50% in less than 3 hours with very little usage.
  3. Boter10
    Cupcake Jan 10, 2017
  4. nemexs
    nemexs , Jan 10, 2017 :
    Had a huge Batter drain just flash all in one kernel toolkit and selected project zhana. Battery life now:
    RAKESH J R likes this.
  5. iNtEnSePL
    KitKat Jan 10, 2017
    And what are top 2 battery draining apps on your phone?
    EDIT: This question needs no answer ;)
  6. robotomatronic
    Froyo Jan 10, 2017
    robotomatronic , Jan 10, 2017 :
    same issue. since updating to 4.0.1. battery drain is insane! any other fix besides uninstalling all Facebook services?
  7. Supreeth Dsouza
  8. BhusanRaj
    Froyo Jan 10, 2017
    BhusanRaj , Jan 10, 2017 :
    same here the phone heats up like nuts... had to switch it off and on time to time. and heats up even when not in use... mainly at the top of the screen
  9. AshuEltero
    Froyo Jan 10, 2017
    AshuEltero , Jan 10, 2017 :
    Drastically battery drainage.... 24% used by facebook app.... bye bye facebook app
    RAKESH J R and iNtEnSePL like this.
  10. G_Rohit_Reddy_SvzL
    iNtEnSePL likes this.
  11. iNtEnSePL
    KitKat Jan 10, 2017
    uninstall, see if it works. use the poll to tell others if idea is good or not (to solve the issue of battery drain, not of not having facebbok app :) )
    If it works, you can install the app again and see if issue is solved. It just might dissappear (can't check it myself, as I donb't use FB at all)
    Other fix - get an Iphone as someone mentioned that it fixes the issue permanently ;)
    G_Sridhar Gupta and Murali559 like this.
  12. iNtEnSePL
    KitKat Jan 10, 2017
    it doesn't mean that something is not using your phone instead of you (like that one bad app). on top of phone are located main chips which get hot.
  13. Unusual_guy
    Ice Cream Sandwich Jan 10, 2017
  14. darrenhw
    Donut Jan 10, 2017
    darrenhw , Jan 10, 2017 :
    Removing FB and Messenger removes the problem! Thanks iNtEnSePL. Instead of draining when on charge, now my phone actually charges on charge! :)
  15. darrenhw
    Donut Jan 10, 2017
  16. WartleS
    Gingerbread Jan 10, 2017
    WartleS , Jan 10, 2017 :
    I can confirm, having Facebook and Messenger is the number 1 cause of battery drain, specially with their latest updates today.
  17. F_Aleksandar_Stojiljkovi
    G_T._A._CxNO and captalex002a like this.
  18. iNtEnSePL
    KitKat Jan 10, 2017
    Who cares, it's the #1 problem solver right now available. There must be some issue on one of sides (or even on Google side, who made Nougat core), but that's what we have right now.
  19. iNtEnSePL
    KitKat Jan 10, 2017
    It's up to you ;)
    If you have battery issue, and don't use (never used FB apps), then the second best solution is to do a factory reset.
    Dr Puneet Sharma likes this.
  20. Ansar Ali
    Donut Jan 10, 2017
