[CLOSED] Lets discuss issues in OnePlus 5T and how to fix !
Thread Status:
Not open for further replies.
  1. G_Shaheer_Ahmad_LxVh
    Froyo Aug 7, 2018
    G_Shaheer_Ahmad_LxVh , Aug 7, 2018 :
    I have OnePlus 5T 8.1 Oxygen version 5.1.4
    Its been 5 months since i bought this phone and i love it. I was also a OnePlus 3T user. Oneplus makes great phone and its a perfect phone out in the market. Everything works great in OnePlus 5T. Except there are some issues that i have noticed.
    1. Google assistant :
    I disabled Google assistant when my phone arrived. So i was thinking why not try it ? So 3 Days ago i enabled google assistant and it was working fine. But after few hours it stopped listening my voice . I have tried everything and i have noticed in the community that i am not only one who is facing the same issue . If anyone knows how to fix it please do share . If not then perhaps we should wait for the update .
    2. Dash charge :
    Not Everytime but sometimes. When i connect my charger it says " Slow charging or Normal charging". If you wait 5 to 10 minutes then automatically dash charge appears otherwise not unless you reconnect your charger. It only happens sometimes.
    If anyone facing the same problem please share and i know there are more minor issues even i dont remember right now. Share that too ! Thanks [e]263a[/e]️
    Lets Talk !
    sathishselvaraj likes this.
  2. sathishselvaraj
    Cupcake Aug 7, 2018
    sathishselvaraj , Aug 7, 2018 :
    i have faced the same Dash Charging Issue , but it's not an issue .
    it depends on the voltage of power we are getting in home or wherever.
  3. U1530073835592
    Cupcake Aug 7, 2018
  4. G_Shaheer_Ahmad_LxVh
    Froyo Aug 7, 2018
    I dont think its about voltage. Try rotating type c ! It works sometimes .
  5. G_Shaheer_Ahmad_LxVh
    Froyo Aug 7, 2018
  6. sathishselvaraj
    Cupcake Aug 7, 2018
    Unpair the headset from other devices and try to connect with OP5T.
    or
    Check the Compatiblity of you Bluetooth Headset
  7. danvxz
    Honeycomb Aug 7, 2018
  8. lakshaykapoor99
    lakshaykapoor99 , Aug 7, 2018 :
    I've also faced this charging issue, but I think mine is related to the wire! Although the cable is perfectly fine but when and if I move it around, dash charging stops suddenly and it switches to slow charging and if I move the cable back to it's place before, dash charging starts again!
  9. izzykasha
    Lollipop Aug 7, 2018
    izzykasha , Aug 7, 2018 :
    so you have disguised your stupidity behind a "let's discuss(talk)" thread
    Are you unable to use search to see that the "OK Google" is a widespread issue caused by "Google" affecting many phones. Google are working on sorting this out
    If you are going to start a let's talk thread make sure you are not making yourself out to be a fool that cannot see the many threads on the Google issue into he forum or even use forum search!!!
  10. 0day
    Cupcake Aug 7, 2018
    0day , Aug 7, 2018 :
    So basically dash charge doesn't work well for you. You live in some slum with an unstable electricity connection.
    As well as you don't know how to search the forums.
    Budruel likes this.
  11. G_Shaheer_Ahmad_LxVh
    Froyo Aug 7, 2018
    i dont think everyone has a damage cable. its about software i think
  12. G_Shaheer_Ahmad_LxVh
    Froyo Aug 7, 2018
    then why didn't i face the same problem with my 3t ? . and i was out of country last month and faced the same problem
  13. G_T_Bennett
    Jelly Bean Aug 7, 2018
    G_T_Bennett , Aug 7, 2018 :
    You've posted this in every thread and continue to get the same answer. I think it's time to give it up.
  14. U1530073835592
    Cupcake Aug 7, 2018
  15. G_T_Bennett
  16. pablofg1978
    Spanish POC Assistant Head Moderator Aug 7, 2018
    pablofg1978 , Aug 7, 2018 :
    pointless thread closed
    Use the search before creating a new thread and use the bug report platform to submit your issue
    Herbert_Lagos likes this.
