[closed]Lineage 15.1 on OnePlus One battery drain very fast
Thread Status:
Not open for further replies.
  1. stefano.r Cupcake Aug 27, 2018
    stefano.r, Aug 27, 2018 :
    Hello everybody,
    First of all I am really sorry for my bad english.
    I flash my OPO to the lineage 15.1 Nightly 20180813 and also the GAPP stock the reboot system, all is fine except the battery, now is going down very fast, 1% per minute at least. :-(
    Someone knows how to fix it ? Is it happen to someone else ?
    Any idea or suggest is appreciate.
    bye
    thanks
    Stefano
  2. DrJMun Jelly Bean Sep 13, 2018
    DrJMun, Sep 13, 2018 :
    I'm having the same problem... but have not found any solution.
  3. Horsault Marshmallow Moderator Sep 14, 2018
    Horsault, Sep 14, 2018 :
    Nightly are beta test versions, as may be stated on LineageOS pages.
    If you don't want to deal with beta test problems, you should probably stand to stable versions.
    You may get more help from LineageOS devs.
    Closed
