[CLOSED]lost phone HOW TO IDENTIFY THE PHONE VAN YOU HELP ME
Thread Status:
Not open for further replies.
  1. Sameer Shaik 555 Cupcake Jan 12, 2019
  2. B_Wrath Lollipop Jan 12, 2019
    B_Wrath, Jan 12, 2019 :
    Delete this post. Don't share imei in public!
    Check android device manager and use the login account of your phone. If phone is switched off, there is nothing you can do. Contact the local authorities!
    Amer_Ezhar likes this.
  3. Ashwinkumar989 Honeycomb Jan 12, 2019
    Ashwinkumar989, Jan 12, 2019 :
    Go and use Google find my device and try tracking down your mobile if you have pattern or pin protected enabled in your phone he can switch off the phone but can't factory reset the phone easily and don't share your imei ID publicly
  4. SoniaB Nougat Senior Moderator Jan 12, 2019
    SoniaB, Jan 12, 2019 :
    I have removed your personal information (IMEI) from the thread title and your start post.
    Please do not post sensitive information publicly on the forum.
    As stated, if you have a Google account set up on your device, you can try to locate it via the find my device feature.
    However, if that does not work then you are out of luck. Best you can do is contact your network carrier and ask them to blacklist your IMEI
    Answered and thread closed
