[CLOSED] max Amps by charging battery
Thread Status:
Not open for further replies.
  1. lexlars
    Froyo Oct 24, 2014
    lexlars , Oct 24, 2014 :
    Hi everybody do you know with how much amps max I can charge the one? Can I charge it with the max mAh of the battery 3100 mAh = 3100 mA at charging? Or is there a protective circuit in the one?
    Louluvre likes this.
  2. Hanson Lee
    Marshmallow Oct 24, 2014
  3. EvilSpeaks
    Jelly Bean Oct 24, 2014
  4. Maximus Decimus Meridius
    Moderator Moderator Oct 24, 2014
    Maximus Decimus Meridius , Oct 24, 2014 :
    Protective on both (charger and device) . thnx for asking.
  5. Hasaan12
  6. Louluvre
    Louluvre , Oct 24, 2014 :
    Ehhhhhhhhhhhhhhhhhhhhhhhhh.............., Why would you even tried to do that........? Are you trying new forms to torture your One?
  7. Nick Heimes17
    Eclair Oct 24, 2014
    dbanez25 likes this.
  8. vitali24
    Cupcake Oct 24, 2014
  9. samyune
    Froyo Oct 24, 2014
    samyune , Oct 24, 2014 :
    I think it would be ok to use a charger rated 3.1A. It is more important that the voltages match. The phone will not pull more than the maximum current it needs to charge.
  10. lexlars
    Froyo Oct 24, 2014
    To everybody who sayed I should use the boxed charger: I want to buy an car charger but I didnt knew how much amps it should have
  11. singhgurdeep
    Gingerbread Oct 24, 2014
  12. dcoulombe
    Ice Cream Sandwich Oct 24, 2014
    dcoulombe , Oct 24, 2014 :
    Try to get a 2A car charger. It will charge using a 1A one, but slower. All my car chargers are 1A and it works fine anyway.
  13. samyune
    Froyo Oct 24, 2014
    Just get 2.1A car charger and you will be good to go.
  14. Raikon_N
    Raikon_N , Oct 24, 2014 :
    The supplied charger/cable combo can provide 1.8A to 1.9A+ during my testing. I previously tried different cable and it only gives around ~0.8A. So always make sure to use the default cable that came with the package for faster charging time. Haven't tried with different charger though, I guess it will be slower as normal charger nowadays at least for phones are rated up to 1.5A only.
  15. gusuraman
    Community Veteran Oct 24, 2014
    gusuraman , Oct 24, 2014 :
    My car charger is 3.2mA. The phone limits the charging to 1.9mA maximum (data collected with battery monitor Widget)
    I feel it heat bit more but maybe because when i charger in car i put the phone on the passenger seat.
  16. dbanez25
    KitKat Oct 24, 2014
    dbanez25 , Oct 24, 2014 :
    i think 3.1A is ok..i used to charge my samsung phones with 2.1A while its only rated for 1A.
  17. Benedikt
    Benedikt , Oct 24, 2014 :
    Kernel standard is 2 100mA, nearly no chargers are able to output 2,1A stable. With original charger I charge with ~1,8A
  18. ah_heng
    Honeycomb Oct 24, 2014
    ah_heng , Oct 24, 2014 :
    I think your car charge charge at a combine 3.2A and not 3.2A on a single port. AFAIK, I haven't seen one with a 3A charge port yet. Maybe I'm wrong ;)
  19. lexlars
    Froyo Nov 3, 2014
  20. 95frass
    Cupcake Jan 6, 2017
