20
Guide [CLOSED]Nougat Rom's for OP2
Thread Status:
Not open for further replies.
  1. The Imp
    Ice Cream Sandwich Mar 2, 2017
    The Imp , Mar 2, 2017 :
    You will have to clean flash to install dynamic gapps.
    #61
  2. The Imp
    Ohh OK I thought you were talking about aosip
    #62
  3. locxFIN
    KitKat Mar 2, 2017
    locxFIN , Mar 2, 2017 :
    If you already have opengapps flashed, then I would suggest clean flashing the ROM first to get rid of opengapps. Once you have Dynamic installed, you don't necessarily have to do a clean flash every time.
    #63
  4. user 7
    user 7 , Mar 2, 2017 :
    Hi.
    I just found a new rom and wanted to inform here.
    Its the nx rom and one member was talking about it in a previous post.
    NX stands for nexus and only nexus devices are fully supported by them.
    Still op2 is a legacy device and has a version of nx rom running on marshmallow. The rom has per app led customisation and several other tweaks but not nougat yet.
    https://plus.google.com/communities/109235522128893190473
    This is link to their community
    #64
  5. The Imp
    I only listed nougat ROM's in this thread thats why I didn't added any marshmallow ROM. Anyways thanks
    #65
  6. itsalyana
    Donut Mar 2, 2017
    itsalyana , Mar 2, 2017 :
    could you please tell me what exactly is the difference between open Gapps and dynamic gapps?
    thanks in advance
    #66
  7. The Imp
    No difference in apps just different in the way they are packaged and dynamic is for arm and arm 64 architecture but for opengapps you have to choose the right one.
    #67
  8. G_Andrei_Barbulescu_SivE
    Cupcake Mar 2, 2017
    #68
  9. Geoffrey.
    Froyo Mar 2, 2017
    Geoffrey. , Mar 2, 2017 :
    I'd recommend XenonHD, I get 3-4hours S.O.T. w/ full brightness, there are no bugs and you can apply theme with préinstallés substratum.
    #69
    Noumpe likes this.
  10. Geoffrey.
    Froyo Mar 2, 2017
    #70
  11. noquarter
    Lollipop Mar 2, 2017
    noquarter , Mar 2, 2017 :
    You can find a large choice of custom Roms in first posts of this thread. Merged
    #71
    theshinybeast likes this.
  12. user 7
    Ice Cream Sandwich Mar 3, 2017
    user 7 , Mar 3, 2017 :
    That depends on your attitude and how you use your device. If you use it for games and calls ,then don't bother to flash anything. If you need the best ram management, battery and taste of real nougat, the its worth it
    #72
    noquarter likes this.
  13. duvelyonker
    Honeycomb Mar 5, 2017
    #73
  14. The Imp
    Ice Cream Sandwich Mar 5, 2017
    The Imp , Mar 5, 2017 :
    Added
    #74
  15. rushilandrews
    Gingerbread Mar 5, 2017
    rushilandrews , Mar 5, 2017 :
    because it wasn't there on our group
    #75
  16. rushilandrews
    there is no best ROM
    #76
    locxFIN likes this.
  17. rishi211292
    Froyo Mar 6, 2017
    #77
  18. rushilandrews
    Gingerbread Mar 6, 2017
    #78
  19. rishi211292
    Froyo Mar 6, 2017
    rishi211292 , Mar 6, 2017 :
    No, she doesn't have best rom !
    it doesn't exist. If there was one true best ROM, do you think there would be other ROMs?
    There is only subjectively best and that's different for everyone. Everyone has different usage patterns and preferences, so when asking for the best, you get the best for them, not the best for you. The only way you'll find the best one for you is by trying them yourself. They're all free, anyway.
    Also, keep in mind that the devs are not competing against each other and they're not trying to win you over or anything. They all have different design goals, they're not trying to be better than one another. They're just trying to be different. Asking for the best is quite disrespectful towards the devs.
    #79
  20. locxFIN
    KitKat Mar 6, 2017
    locxFIN , Mar 6, 2017 :
    Mother of Kang..
    #80
