20
Guide [CLOSED]Nougat Rom's for OP2
Thread Status:
Not open for further replies.
  1. The Imp
    Ice Cream Sandwich Mar 28, 2017
    The Imp , Mar 28, 2017 :
    try cosmic, du and aosip all are good so you can try any of these.
  2. The Imp
    sorry don't know the answer to that question.
  3. The_Phantom_DJ
    Gingerbread Mar 28, 2017
  4. Vijayamuralidhar
    Vijayamuralidhar , Mar 28, 2017 :
    Can u please explain between super su systemless., Stable oos and latest. ,,,,, please.. i am noobie to this area
  5. The Imp
    Systemless or OOS SuperSU should be used for rooting OOS if you root with other versions than it will cause bootloops.
    Latest will have latest features it will not work with OOS but will work with custom ROM's. Stable as the name suggests it is stable SuperSU and it can be only used with custom ROM's.
    Ps- you can use systemless SuperSU with custom ROM's too.
    Hope this solves your doubt.
  6. The Imp
  7. Flyologist
    Jelly Bean Mar 28, 2017
  8. ShortyEx
    Ice Cream Sandwich Mar 29, 2017
  9. The Imp
  10. Rogier123
  11. ShortyEx
    ShortyEx , Mar 29, 2017 :
    That's true, but it would also be easier if some people would just read the sticky thread about it :D
  12. The_Phantom_DJ
    Gingerbread Mar 29, 2017
  13. Flyologist
    Jelly Bean Mar 29, 2017
    The Imp likes this.
  14. Zefty
    Eclair Mar 30, 2017
  15. The Imp
    Ice Cream Sandwich Mar 30, 2017
    The Imp , Mar 30, 2017 :
    My battery life would be different than yours so can't help you in that.
    Anyways try cosmic, aosip, du or rr.
  16. rarog
    Lollipop Assistant Head Moderator Apr 3, 2017
    rarog , Apr 3, 2017 :
    Thread closed as requested by the thread starter. Thx for your effort you offered the others. :)
    The Imp likes this.
