2
OxygenOS [Closed]"OK Google" does not work proper when the screen is locked/unlocked
  1. Steven_Petrillo
    Froyo May 28, 2019
  2. Voss
    Eclair May 29, 2019
    Voss , May 29, 2019 :
    Google delivered an update for the Google app. Now everything works fine.
    Thanks to all who helped here.
  3. JorgeMaTeixeira
    Froyo May 29, 2019
    JorgeMaTeixeira , May 29, 2019 :
    Can you share some ss with yours configurations? Here even after the Google app update still not work..
  4. Voss
    Eclair May 29, 2019
    There's not much to configure. 1. Activate voice match. 2. Make sure your assistant is generally associated.
    See the screenshots below.
    Can you open the assistant manually?
  5. JorgeMaTeixeira
    Froyo May 29, 2019
    Yes, after i press the mic button i can talk to the assistant, but ok google command didn't work at all.
  6. Voss
    Eclair May 29, 2019
  7. JorgeMaTeixeira
    Froyo May 29, 2019
  8. Voss
    Eclair May 29, 2019
    Hmm, strange. What happens if you open the assistant manually and say "OK Google"?
  9. JorgeMaTeixeira
    Froyo May 29, 2019
    Nothing :p
  10. Voss
    Eclair May 29, 2019
    Press the mic button an say "OK Google". I only want to know if the assistant interprets this command.
  11. JorgeMaTeixeira
    Froyo May 29, 2019
  12. Voss
    Eclair May 29, 2019
    WTF... [e]1f62d[/e]. Looks like Google has some problems with the assistant...
  13. JorgeMaTeixeira
    Froyo May 29, 2019
    Ok google in that altíssima) situation works, the phone says hello Jorge.
  14. Voss
    Eclair May 29, 2019
    Can you check the Google Play Store again for new updates...
  15. JorgeMaTeixeira
    Froyo May 29, 2019
    No updates, I'm already in the latest version.. Now works only with the phone locked.
  16. Militant Asian
    Cupcake Jun 18, 2019
  17. JorgeMaTeixeira
    Froyo Jun 18, 2019
