Other [CLOSED] OP7 Pro OOS 10.0.1 issue. via OnePlus 7 Pro
Thread Status:
Not open for further replies.
  1. sketrick
    Eclair Oct 20, 2019
    sketrick , via OnePlus 7 Pro , Oct 20, 2019 :
    Can't drag my keyboard to the bottom of the screen was able to do that on android 9. Now there's an unused chunk that hinders my typing experience.
  2. Alvie
    The Lab - OnePlus 5T Reviewer Oct 20, 2019
    Alvie , Oct 20, 2019 :
    Are you sure it was like that with 9.0 also? Mine always had that gap
    Edit: nvm, I've been using Gboard and not SwiftKey
  3. sketrick
    Eclair Oct 20, 2019
    Alvie
    Edit: nvm, I've been using Gboard and not SwiftKey​
    Yeah SwiftKey always was at the bottom of the screen witch was great. Also I can make the gap even bigger but can't make it smaller that's most annoying thing in Android 10 so far
  4. nihalali
    Eclair Oct 20, 2019
    nihalali , via OnePlus 7 , Oct 20, 2019 :
    Dear member,
    This is an OP7 General Support category and not a place to ask ur OP7 Pro issues...you have a dedicated OP7 Pro General Support category where u can raise issues..
    Coming to ur question, that black bar at the bottom is a part of Android 10 UI.. u can do nothing to remove it.. (until OP or Google comes with a fix in future updates).
    Alvie likes this.
  5. Alvie
    As @nihalali stated, this is an android 10 thing rather than a OnePlus issue. They may be able to change this but I'm not entirely sure of the likelihood of this.
    nihalali likes this.
  6. gaster
    Lollipop Moderator Oct 20, 2019
    gaster , Oct 20, 2019 :
    Hi friend. There's already an existing thread about the Oxygen OS 10.0.1 for the OnePlus 7 Pro here https://forums.oneplus.com/threads/oxygenos-10-0-1-for-the-oneplus-7-pro-and-oneplus-7.1117547/, that you could post your concerns to. There is no need to open a new thread that it will be a pointless one. Also you can report any bugs or suggests any improvements to the Feedback section here https://forums.oneplus.com/feedback/. I am closing now this thread. Please next time use the search function before posting a new thread. Thank you!
    sketrick likes this.
