[CLOSED] OxygenOS 11.0.2.2 for OnePlus 8 & 8 Pro via OnePlus 8
Thread Status:
Not open for further replies.
  1. NickAjay
    Cupcake Nov 26, 2020
    NickAjay , via OnePlus 8 , Nov 26, 2020 :
    Hi Everyone,
    In the recent post on the OnePlus forum. We got to know that they have started to push stable OxygenOS 11.0.2.2 for OnePlus 8 & 8 Pro.
    The latest OxygenOS 11.0.2.2 OTA update for OnePlus 8 and 8 Pro features several system improvements including optimization to frame stability algorithm for a smoother experience. It also fixed the issue that play store could not install apps and background process management to improve standby-by performance. OOS 11.0.2.2 also features a newer Android Security Patch from November 2020. Most importantly, They have fixed the network issue which was reported by many of the users.
    Also Read: OnePlus 8 & 8 Pro Gets OxygenOS Open Beta 4 : Download Now
    As per OnePlus, these are the changelogs of the above builds
    Changelog
    System
    • Optimized the experience with a split-screen of apps
    • Further optimized system power consumption and increase battery life
    • Fixed the small probability issue that expanded screenshot may stop working
    • Fixed the issue that cache is not deleted after uninstalling apps
    • Fixed the issue that the screen may flash when using fingerprint unlock
    • Fixed the issue that Horizon light is not activated normally
    • Fixed the small probability issue that NFC can not be turned on
    • Fixed the small probability issue that Parallel Apps can not be turned on
    • Fixed the issue that Play Store could not install the app
    • Updated Android security patch to 2020.11
    Network
    • Fixed the small probability issue that network interruption issue in some apps
    • Improve the stability of communication functions
    Download OxygenOS 11.0.2
    https://networktips.in/oxygenos-11-0-2-2-for-oneplus-8-8-pro/
  2. K1605331543332
  3. Neoharys
    Eclair Nov 29, 2020
  4. pablofg1978
    Nougat Head Moderator Nov 29, 2020
    pablofg1978 , Nov 29, 2020 :
    Hello there
    Please read and use the official update thread for any update related discussion
    https://forums.oneplus.com/threads/oxygenos-11-0-2-2-for-the-oneplus-8-and-oneplus-8-pro.1350788/
    Thread closed
    kaihp likes this.
