162
[CLOSED] OxygenOS 3.2.2 OTA update will start soon on OnePlus 3
Thread Status:
Not open for further replies.
  1. Ashish rajoria
    Eclair Jul 26, 2016
    Ashish rajoria , Jul 26, 2016 :
    Iam facing battery drain issue on my one plus 3. Can you fix the battery drain issue in next update? Many of users are facing and issue
  2. kkap09
    Donut Jul 26, 2016
    kkap09 , Jul 26, 2016 :
    You can actual disconnect vpn after the download starts (I paused before I disconnected though) and it will download a lot faster. I went from 300 KBps to 1-2 MBps
    Godstoy likes this.
  3. otto2
    Photography Expert Jul 26, 2016
    otto2 , Jul 26, 2016 :
    Don t know what you re talking about. Maybe you should check your apps first, than wipe cache in recovery mode and try a full factory reset, before posting here, especially when you re not adding Screenshots and more details
  4. dwlimf
    Froyo Jul 26, 2016
    dwlimf , Jul 26, 2016 :
    Yea I was hopeful it was fixed.
    I had my phone with 3.1.2 and the VoLTE was working super, it as crystal clear OP3 to OP3 with the enhanced LTE voice enabled. Once I updated to 3.2.1 can't even make a call without the other end saying they can't hear me.
    I sent logs into OP from failed calls so I am hopeful that they will fix it.
    Deactivated User likes this.
  5. Albela
    Froyo Jul 26, 2016
    Albela , Jul 26, 2016 :
    Woohoo getting the update now! Used Snap VPN and used UK proxy to check the update. Once it was available removed the VPN and started downloading. As you can see I'm getting pretty good speeds.
    Charan99 likes this.
  6. Xenti3
    Honeycomb Jul 26, 2016
    Xenti3 , Jul 26, 2016 :
    OPX might as well be on the back burner since they took on the OP3 it seems they cant develop for more than 2 very effectively.
    laurboss likes this.
  7. F_Nathan_Dugger_qiBD
    Cupcake Jul 26, 2016
    F_Nathan_Dugger_qiBD , Jul 26, 2016 :
    Thank you for the update!! I really appreciate it!! Also, can we possibly get more wallpapers? Preferably more live wallpapers?:)
  8. dwlimf
    Froyo Jul 26, 2016
    Please try this it worked for me.
    Under Storage and Cache clear the Cached data, turn off the phone, hold the vol down and power and release when it boots, select english, then clear cache and date, then clear cache (do not select clear data), then chose reboot.
    This should fix any issue assuming you don't have some crazy app that is actually draining your battery.
    Try it, it has a good chance to fix it.
  9. Remo1_2 020
    Eclair Jul 27, 2016
  10. Techder
    Ice Cream Sandwich Jul 27, 2016
    Techder , Jul 27, 2016 :
    Still no 60 fps and ois for 1080p?
    Devvor likes this.
  11. Auristic
    Lollipop Jul 27, 2016
    otto2 likes this.
  12. stephenboyo
    KitKat Jul 27, 2016
    stephenboyo , Jul 27, 2016 :
    People are never satisfied, before it was that the sensor wasn't sensitive enough and now it's too sensitive:eek:
    otto2 likes this.
  13. ttmxlive
    Gingerbread Jul 27, 2016
    ttmxlive , Jul 27, 2016 :
    Ok but I tried navigating with GPS alone and still get signal being loss....slight improvement but thanks thao.
  14. opodepe
    Cupcake Jul 27, 2016
  15. Albela
    Froyo Jul 27, 2016
    Albela , Jul 27, 2016 :
    What mic issue?! People seem to have issues with every peripheral now.
    kylesweet and otto2 like this.
  16. Spike83420
    Yavuz Is and otto2 like this.
  17. ttmxlive
    Found a New Bug in v3.2.2:
    The camera 1080P and 720P recording is quite choppy while 4K is really great....in v3.2.1 all video recording modes are smooth....I already did 5 sets of cache wipes in recovery mode, clear the app data and the issue is still there.
    Have anyone tried the video recording in all modes on Oxygen OS v3.2.2?
    Any issues?
  18. christianleyva
    Froyo Jul 27, 2016
    christianleyva , Jul 27, 2016 :
    Speed 3.4 MB/S
    1. I Used VPN
    2. Shutdown the VPN after Update Alert
    3. Disable WiFi and Use 4G - Through Wifi 24 kb/s
  19. Dishlexic
    Froyo Jul 27, 2016
    Dishlexic , Jul 27, 2016 :
    Impressive Oneplus.... Listening to your users annnnnnd acting on it. Maybe the third time really is the charm. Can you keep it up?
    Yavuz Is likes this.
  20. alirezanasibi
    alirezanasibi , Jul 27, 2016 :
    I confirm this issue in both 720 and 1080!
