91
ROM [CLOSED] OxygenOS 3.x_OPX_Port_for OPO_by_PMehra
What u want in next release?
Poll closed Aug 31, 2016.
  1. Change in Music player
    17.3%
  2. Without maxx audio and saperate maxx audio zip
    19.9%
  3. Custom kernel
    39.7%
  4. UKM support
    17.9%
  5. Inbuilt xposed
    28.2%
  6. Old bootanimation
    5.1%
  7. Nothing. (My Fav option)
    15.4%
Multiple votes are allowed.
Thread Status:
Not open for further replies.
  1. pradeepsmehra
    Ice Cream Sandwich Jan 26, 2016
    bidi1985 likes this.
  2. ElRobertson
    Gingerbread Jan 26, 2016
    ElRobertson , Jan 26, 2016 :
    Maybe a Bug: The Audio from recorded Videos is bad/has noise ...
    Can someone else check this?
  3. markitosd
    Froyo Jan 26, 2016
    markitosd , Jan 26, 2016 :
    The great quality of your ports make me dream about you porting Windows 10 on the OPO :D
    PCesar.Cercal and -HUGO- like this.
  4. mukesh22584
    Eclair Jan 26, 2016
  5. PCesar.Cercal
    KitKat Jan 26, 2016
    PCesar.Cercal , Jan 26, 2016 :
    Where is the download link for opo the 2.2.0 portes?
  6. markitosd
    Froyo Jan 26, 2016
    mrcndr82 likes this.
  7. Quzer
    Froyo Jan 26, 2016
    Quzer , Jan 26, 2016 :
    @pradeepsmehra I found a bug i cant give the Hardware Keyz comments like double tap to sleep . And can you change the bootanimation to the old one ?:)
  8. mrcndr82
    mrcndr82 , Jan 26, 2016 :
    Is it possibile to extract the camera apk to try to install it to oxygen 2.1.4 and see what happens with manual mode? Or does it need some underlying apis not implemented in 2.1.4 os version?
    bright_wal and Quzer like this.
  9. Serg_Bay
    Donut Jan 26, 2016
  10. Echo_2000
    Froyo Jan 26, 2016
    Echo_2000 , Jan 26, 2016 :
    Can someone extract the Oxygen Camera apk Form the 2.2.0 port with the manuel mode and uploade here? Thank you.
    bright_wal and mrcndr82 like this.
  11. LenOremovic
    Eclair Jan 26, 2016
    LenOremovic , Jan 26, 2016 :
    I am on your oxygen 2.1.3 with systemUI flashed . Is there any diffrenece between flashing ota to 2.2.0 or downloading full zip. And how does the new bootanimation look?
  12. okak24
    okak24 , Jan 26, 2016 :
    Hello thanks for your excellent work. I want only modem and radio files for flash in last cos12.1.1 version. Can you upload only this files? And do you know if i can flash this modem in cos without problem or any brick? Thanks and keep good work
  13. Ajjz6080
    Froyo Jan 26, 2016
    Ajjz6080 , Jan 26, 2016 :
    @pradeepsmehra I see a lot of kudos for you through out the thread, so thumbs up for all that you do. Trust me it matters a lot regardless of what you think.
    Quick question for users of the ported version from Oxygen OS 2.2.0 from OPX and system ui from 2.1.4 for OPO -
    1.) Does this come with a better/improved kernel? I think the CPU boost on the original 2.1.4 is way too high and causes a serious dip in screen on time? Hoping that this version has some improvement on that front.
    2.) Does this also has the annoying vibration when double tap to wake is triggered?
    3.) Does this have the proximity wakeup for the ambient display like in the Oxygen OS 2.1.4 with configurable hardware button actions from 2.1.4?
  14. FalconFX
    Honeycomb Jan 26, 2016
    FalconFX , Jan 26, 2016 :
    @pradeepsmehra Kudos for the impressive work on this ROM man, but i have one issue with the backlight keys sometime staying on when the screen is off, i dont want to disable them, I prefer hardware keys, but sometimes they stay on after i lock the device :)
  15. aowa85
    Donut Jan 27, 2016
    aowa85 , Jan 27, 2016 :
    good rom but so sad for no NFC i want NFC for connecting my camera
  16. pradeepsmehra
    Ice Cream Sandwich Jan 27, 2016
    pradeepsmehra , Jan 27, 2016 :
    Yes i know about this bug...its dependency of systemUI...
    for bootanimation will give you tonight..
  17. pradeepsmehra
    Please confirm this bug, i will remove maxx audio if any noise ..
  18. pradeepsmehra
    nothing difference ...
    bootanimation cant describe in words...:D
  19. pradeepsmehra
    1> yes, screen on time is 7+ Hr
    2>yes
    3>dont'know may any user can confirm this.
    Buddy, you look like perfectionist ...I dont think porting is for you, you have to stick with the official release..
    & ask them where is maxx audio...
    where is the version 2.1.0, 2.1.1, 2.1.2 & 2.1.3
  20. pradeepsmehra
    Yes this is issue from 1st day, sometime led keep wake after device lock..its not a major bug so i never look into this..
    now i will see if i can do something for this bug.
    FalconFX likes this.
