[closed] please help. charging issue.
Thread Status:
Not open for further replies.
  1. shashik008
    Froyo Mar 29, 2017
    shashik008 , Mar 29, 2017 :
    Hi. I am using one plus 2 since one and half year. After 3.5.6 I am facing the issue of charging times. It's taking forever to charge from 0 to 100.
    . Please resolve this issue. It took 2 and half hours to charge from 6% to 44%.
    btw i am using official oneplus adapter and charging cable. i did a factory reset after 3.5.8. no use. tries charging via oneplus powerbank . no use
    shayanzahedana likes this.
  2. JustAPhone
    Ice Cream Sandwich Mar 29, 2017
    JustAPhone , Mar 29, 2017 :
    another one... OP should seriously look into this... if not some of the people here will keep asking to buy new cables...
    shashik008 and shayanzahedana like this.
  3. prashantshyamu
    Cupcake Mar 29, 2017
    shashik008 likes this.
  4. laurboss
    Honeycomb Mar 29, 2017
    laurboss , Mar 29, 2017 :
    Even if the cable is ok (i don't know if it is in your case), you will still have a longer charging time when having WI-FI ON and doing stuff on the phone. Just don't use it while charging or charge it TURNED OFF to have the fastest charging time. :rolleyes:
  5. iAnkur
    Gingerbread Mar 29, 2017
  6. shashik008
    Froyo Mar 29, 2017
    i tried using other cables too. same issue. i tried charging via powerbank. no solution. i did a factory reset too after 3.5.8.
  7. shashik008
    Froyo Mar 29, 2017
    will try turning wifi off. thank you
  8. shashik008
    Froyo Mar 29, 2017
    i tried using powerbank too, but no use. btw i am using official pneplus charger and cable.. even the powerbank is oneplus's
  9. JustAPhone
    no use... is the same.... just bear with it....
    some friends here the phone is ok after buying other brand or cable and charger.... but i tried still the same.. maybe you have the luck.... you can try.
  10. shashik008
    Froyo Mar 29, 2017
    :(:(:(:cry::cry::cry:
  11. shashik008
    Froyo Mar 29, 2017
    hi to all. i too faced the issue of charging time on my oneplus 2 . it took more then 8 hours to charge from 0 - 100% using my original oneplus adapter and cable provided in the box.i tried charging my phone with powerbank using the same cable . its of no use.
    Solution. : i tried charging with the micro usb cable with oneplus ISB type c adapter .wollaah it worked .btw i have charged using powerbank not via plug box(switch board)
  12. Ieiijnkdmsk
    Froyo Mar 29, 2017
  13. kailas6
    kailas6 , Mar 29, 2017 :
    Did u tried using another oneplus 2 data cable and another oneplus adapter..?
  14. Lancelot_69
    Lollipop Mar 29, 2017
    Lancelot_69 , Mar 29, 2017 :
    Don't replace your battery!!! Blow out the usb ports on the charger and the phone. Wipe all contacts with a lens cleaner type cloth. Start charging your phone after a couple of minutes it will tell you charge time. If it is 2+hours, remove the cable from the charger, turn it around and reinsert it in the adapter. Now waiting a couple of minutes and see if charging times changed
  15. pranay8
    pranay8 , Mar 29, 2017 :
    I am facing the same issue. can you please elaborate how one can solve this.
  16. shashik008
    Froyo Mar 29, 2017
    just get a type c usb adapter and charge your device i used a 5 volt 2 amp samsung charger. just attach a type c usb adapter and you are good to go
  17. 549448
    Donut Mar 29, 2017
  18. G_Chris_Murphy_ymNT
    Eclair Mar 29, 2017
    G_Chris_Murphy_ymNT , Mar 29, 2017 :
    if you left your phone plugged in constantly at one time, or did not let the battery drain fully before charging, these scenarios would affect the battery condition of the phone, contact one plus if you still have warranty or if not then repair yourself by buying a new battery online and repairing it yourself.
  19. G_Harishankar_Gupta_xdac
    Donut Mar 29, 2017
  20. shashik008
    Froyo Mar 30, 2017
    shashik008 , Mar 30, 2017 :
    suddenly 3.5.6 i am facing issues of charging. it takes for ever to charge. it takes more than 8 hours to charge fully. btw i am using official one plus charger.. temporary solution. : k am using oneplus powerbank with type usb adapter. it charges my device fast as usual.
