3
[CLOSED]poco f1 gets 960fps super slow....
Thread Status:
Not open for further replies.
  1. K1524108079204 Gingerbread Dec 5, 2018
  2. sujithkumarb Froyo Dec 5, 2018
  3. B_Wrath Lollipop Dec 5, 2018
    B_Wrath, Dec 5, 2018 :
    I said chip. Not chipset. Even the sensor matters. I don't think IMX 398 is capable of anything more than 240FPS.
  4. IVishalGandhi Gingerbread Dec 5, 2018
    IVishalGandhi, Dec 5, 2018 :
    You are saying OnePlus is the not cheap.
  5. stark2991_PL KitKat Dec 6, 2018
    Stickied Post
    stark2991_PL, Dec 6, 2018 :
    Dear people. If the hardware isn't capable of capturing 960fps slo-mo, then how can they add it in a update?
    In order to record 960fps phone has to have:
    a) processor with 960fps recording support
    b) camera with a special DRAM buffer
    If one of these is not present, you will not get a true 960fps
    If the Poco F1 will get super slo-mo, then it will only be a software interpolated 240fps or something like that. Software will create missing frames, so the image quality won't be much better than with 240fps
    https://www.xda-developers.com/xiaomi-poco-f1-miui-10-beta-960fps/
  6. Malg220 Gingerbread Dec 6, 2018
  7. Y1536651524713 Donut Dec 6, 2018
    Y1536651524713, Dec 6, 2018 :
    haha agreed
  8. MarcioReis87 Ice Cream Sandwich Dec 6, 2018
    MarcioReis87, Dec 6, 2018 :
    Yup, I'm a happy 5t user but my next one is def going to be a Xiaomi. It's cheaper, same build quality, way faster updates than OnePlus. Christ, look how long they take for a PIE update.
    Imagine installing a custom Google ROM on a Mi Mix 3, priced the same as a 5T.
    It's my 3rd OnePlus device but I can say that OP is becoming greedy.
    This will def be my last OnePlus device, so disappointed...
    I might go with an Honor aswell, cheap but robust and i like Kirin and look at huawei fast charge, it's phenomenal...
    gargyagotra likes this.
  9. MarcioReis87 Ice Cream Sandwich Dec 6, 2018
    so what? OnePlus does none of that... For me, it's no gimmick but an actual feature that has been praised in many reviews.
  10. OskarsBk Eclair Dec 6, 2018
    OskarsBk, Dec 6, 2018 :
    Well I must partially agree. I have a 5T, I'm not disappointed with it. But updates for it come a lot slower than other devices. But I like Oneplus software a lot better than Xiaomi or even Google. I think that oneplus has one of the best Android softwares available.
    MarcioReis87 likes this.
  11. G_Prateek_Mishra_dFiG Honeycomb Dec 7, 2018
    G_Prateek_Mishra_dFiG, Dec 7, 2018 :
    Apart from these OnePlus is getting side tracked with OnePlus TV.
    They are not able to cover all the phone for OS upgrade. How are they going to manage another product all together.
  12. raghu6763 Honeycomb Dec 8, 2018
    raghu6763, Dec 8, 2018 :
    guys let me tell you...
    poco f1 is much better than op 5t.. leave about 5t its better than 6 or 6t...
    check mkbhd blind camera test..
    poco f1 is next only to mighty mate 20...
    come out of the marketing drug of OP
    am using poco F1, have been using op 5t earlier...
    was fed up with the situation of beta updates for op 5t.
    now F1 already has pie and very good camera output
    Akhil Rajan11 and OskarsBk like this.
  13. pablofg1978 Spanish POC Assistant Head Moderator Dec 8, 2018
    pablofg1978, Dec 8, 2018 :
    Thanks , I put this post pinned.
    Answered
    Pointless thread closed
    stark2991_PL and Intruder71 like this.
