[Closed]Poor battery performance on oneplus 6 devices via OnePlus 6
Thread Status:
Not open for further replies.
  1. iammrkt
    Froyo May 31, 2020
    iammrkt , via OnePlus 6 , May 31, 2020 :
    Battery back up has been gradually worsening faster than expected on Oneplus 6 device. Has to be charged 2 to 3 times a day with moderate usage.
    While we all understand that a 2 year old device wouldn't give battery back up as a new one, the performance should not be that poor either. All apps are using battery normally as per the stats. Phone has been factory reset with no app backup. Still no difference. Any fix will be appreciated.
    nairsantho likes this.
  2. Artemus.
    Nougat May 31, 2020
    Artemus. , May 31, 2020 :
    One word: calibration. That's the key.
    Caomhin likes this.
  3. iammrkt
    Froyo May 31, 2020
    I am more interested in solutions dather than technical jargons..There are a lot out there to defend the brand. I was looking for a solution actually.
  4. Artemus.
    Nougat May 31, 2020
    This is the solution: calibration. Take it away, @Caomhin!
    Caomhin likes this.
  5. Caomhin
    Lollipop May 31, 2020
    Artemus. likes this.
  6. Cervantes
    Lollipop Moderator May 31, 2020
    Cervantes , May 31, 2020 :
    Hi
    Please, check and use this thread for all battery questions
    for another user to suggest: upload a screenshot of:
    battery and other
    battery uses
    Use the search engine before opening a new thread
    Thread closed
    Artemus. and Caomhin like this.
