[CLOSED]Problem after update to 8.0.0
Thread Status:
Not open for further replies.
  1. RandomDude66613
    Gingerbread Nov 20, 2017
    RandomDude66613 , Nov 20, 2017 :
    For a some reason this thing keeps popping up every 10 sec and then disappear second later, I didn't even have a chance to mute it or to do something else with it. What it this and how to fix it?
    Jassijee likes this.
  2. PushpakRoy
    Honeycomb Nov 20, 2017
    PushpakRoy , Nov 20, 2017 :
    Force stop transit I guess?
    Else it will be always there running in the background and the notification will keep popping up.
    pPhilex likes this.
  3. ushai
    Eclair Nov 20, 2017
  4. RandomDude66613
    Dude... I just did the clean installation and spent couple of hours of settings up and login in into everything[e]1f602[/e]
  5. RandomDude66613
    Yeah, probably the best solution so far I can think of... Maybe I should remove the widget from a "shelf"...
  6. Luxemberg Nixon X
    RandomDude66613 likes this.
  7. RandomDude66613
    Yeah in every thread there is a guy who always have a "solution" to every kind of problem... FACTORY RESET...
    Jassijee and Luxemberg Nixon X like this.
  8. PVS Kharoud
    Marshmallow Senior Moderator Nov 20, 2017
  9. RandomDude66613
    Yeah but it kept popping up every 10 sec till I removed the widget from a shelf...
  10. amirhussaini93
    Ice Cream Sandwich Nov 20, 2017
    amirhussaini93 , Nov 20, 2017 :
    bro, that Oreo feature. you can disable it I think, but forgot where to disable it. press long time at that noti?
    or just ignore it. it just report to you what running background, what is high use battery, app using GPS and so on. hahaha.
  11. gnu101
    gnu101 , Nov 20, 2017 :
    it's that live wallpaper but that Android system is annoying as f...
  12. F_Anindo_Ashraf_FGiY
    Cupcake Nov 20, 2017
  13. SurajLoharia
    Jelly Bean Nov 20, 2017
    SurajLoharia , Nov 20, 2017 :
    This is known bug of Oreo
    N only a update can resolve this even pixel phones had this but now they are updated to 8.1
    There is no such issue
  14. gnu101
    notifications ....dot dot dot...show system... Android system...apps running in background ***switch it to low
    Saurabh40629 and Jassijee like this.
  15. nody_chandam
    Eclair Nov 20, 2017
  16. Dinesh_T
    Dinesh_T , Nov 20, 2017 :
    There is a different thread for this problem in feedback section . You can Check there.
  17. Rishvan
    Froyo Nov 20, 2017
    Rishvan , Nov 20, 2017 :
    Hey how did you put the weather on quick tiles?
  18. ghostofcain
    Marshmallow Nov 20, 2017
    ghostofcain , Nov 20, 2017 :
    If you have an issue with the release please raise it, preferably after reading, in the release thread.
  19. BuddysSystem
    BuddysSystem , Nov 20, 2017 :
    about an hour after the oreo update installed my phone went dark, and shut down , that has never happened to me before , i love my 3t and am looking forwrd to purchasing another one plus in the future, can someone help is there any way to fix this , nothing is working
  20. SoniaB
    Nougat Senior Moderator Nov 20, 2017
    SoniaB , Nov 20, 2017 :
    That is native to Oreo.
    You can check this: https://www.xda-developers.com/hide-app-running-background-notification-android-oreo/
    or refer to this thread: https://forums.oneplus.net/threads/avast-after-android-o.684968/
    Thread closed
    bhines5 and ghostofcain like this.
