ajitraj89 , via OnePlus 7T , Feb 26, 2021 : I am running one plus beta build based on android 10 earlier on my one plus 7t and triggered a setting on that when I pick (lift) my phone it lower (reduce) the ring volume. Recently I updated to Op7t o2 beta1 and looking for that setting to turn it off because it makes some trouble while put in pocket. Now I can't get that option in setting menu to turn it off. Any help will be deeply Appreciated. Thanks
J4t1np4r3kh , Feb 27, 2021 : Go to Dialer App --> 3 Dots in top right corner --> Settings --> Sounds and Vibrations --> Raise to lower ringtone Hope that helps!
Aaron2017 , Feb 26, 2021 : All beta related things must be discussed in the beta thread, no need to create a seperate thread about it. https://forums.oneplus.com/threads/...or-the-oneplus-7t-and-oneplus-7t-pro.1387521/
J4t1np4r3kh , Feb 27, 2021 : His issue isn't a beta issue, it's really just looking for a setting 🤷♂️
