[Closed] @Pubg
Thread Status:
Not open for further replies.
  1. X1513001495748
    Gingerbread May 28, 2018
    X1513001495748 , May 28, 2018 :
    See the attached screenshot. This settings works best for me, but it drains my battery like crazy. You can reduce it as per your requirement and check what suits you, but don't increase it otherwise you will have to plug charger and play.
    G_plusone likes this.
  2. Adistyles
    Froyo May 28, 2018
    Adistyles , May 28, 2018 :
    actually I have one plus 5t but everytime I play this game it heats up very quickly tell me what to do
  3. X1513001495748
    1) Remove cover of your phone while you play.
    2) Keep graphics settings to 'smooth' and frame rate settings to'balanced'
    3) If its still getting hot then play in a Air-conditioned room.
    G_plusone, Budruel and Adistyles like this.
  4. Matt 80
    Lollipop May 28, 2018
  5. Adistyles
    Froyo May 28, 2018
    dav boro koru tuka [e]1f602[/e][e]1f602[/e][e]1f602[/e]
  6. Adistyles
    Froyo May 28, 2018
    you have original one then give me [e]1f602[/e][e]1f602[/e]
  7. Punk_69
    Budruel and G_plusone like this.
  8. Adistyles
    Froyo May 28, 2018
  9. Punk_69
    Punk_69 , May 28, 2018 :
    Don't be lazy to explore settings yourself .
  10. Adistyles
    Froyo May 28, 2018
    it is not about the lazy..., it just I don't know the proper setting of this game if you know then tell me
  11. Baymax
    Starting Point Expert Community Expert May 28, 2018
    Punk_69 likes this.
  12. VenkUU
    Ice Cream Sandwich May 28, 2018
    VenkUU , May 28, 2018 :
    The Time Which You Wasted Here Asking For Settings You Would Have Found Settings Or You Could Have Played game and got killed 100 times
  13. Punk_69
    It definitely is about being lazy.
    • Some search in Google (you didn't)
    • Some search in YouTube (you didn't )
    • Some explore the settings and make their own custom ones (you definitely didn't )
    Send what, nudes ?
    Baymax likes this.
  14. VenkUU
    That Duplicate Was Yours
  15. Adistyles
    Froyo May 28, 2018
    ok but if you know the settings then tell me
  16. Punk_69
    And he asks others not to be lazy
  17. Adistyles
    Froyo May 28, 2018
    Punk_69
    Send what, nudes ?​
    you keep that also on your phone or what[e]1f602[/e][e]1f602[/e]
  18. Punk_69
    You never know when you might need it.
    Well what you actually need now is to "search the internet", its an easy Google search!!! But nope you're "active" enough to ask it in the forum of the mobile phone
    #38
  19. Adistyles
    Froyo May 28, 2018
    ok if you don't want to tell then don't tell
    #39
  20. camohan
    Marshmallow Moderator May 28, 2018
    #40
    Punk_69 and Baymax like this.
