6
[CLOSED]screen burn issue on my op5 after playing pubg
Thread Status:
Not open for further replies.
  1. Waveform Modifier
    Marshmallow May 3, 2019
    Waveform Modifier , May 3, 2019 :
    No. Burn-in is a physical damage done by the user. It's been well established everywhere on the forum and the internet. It will suit you better if you just search the internet before posting.
    Nick 59 likes this.
  2. MarcioReis87
    Ice Cream Sandwich May 4, 2019
    MarcioReis87 , May 4, 2019 :
    If it's barely noticable it might go away. When I say that is when you stop playing PUBG, and if you still see very slightly the bag icon right after leaving your game it might be temporary.
    After I play PUBG for like 3 hours straight, I put on a perfectly white screen, pumped the screen at max brightness and in upper left corner of my screen was still the bad icon, very fade barely noticeable.
    What I did was I left the phone to rest, lower the brightness at it's minimum, didn't play PUBG for 2 days and it was pretty much gone. No burn in whatsoever. In the 3 day, I opened PUBG and changed the icons location to not make those pixels suffer again.
    What I simply did was not magic, every time I play a game intensively I never put my screen to the max brightness, ever. secondly I watch out for the temperature since it's a screen and battery killer.
    If burn in starts to appear ever so slightly when really heckling for it, there's still hope to fix it. If you can see the burn-in in normal circumstances/uses, then it's way to late.
    If it's already like this it's too late to save it..
    Budruel and stark2991_PL like this.
  3. PokiX
    Jelly Bean May 4, 2019
    PokiX , May 4, 2019 :
    Always wondered why people need full brightness. There should be a warning to inform user of the risks (not talking about battery drain..)
    Sargo likes this.
  4. Waveform Modifier
    Marshmallow May 4, 2019
    Waveform Modifier , May 4, 2019 :
    But still, that requires reading.
  5. justwondering
    Gingerbread May 5, 2019
    justwondering , May 5, 2019 :
    My 5t had screen burn from the oneplus standard placement of the signal icons and navigation icons, oneplus a few weeks ago replaced my screen for free under warranty.
  6. RAOPREETAM
    Cupcake Jul 10, 2019
    RAOPREETAM , Jul 10, 2019 :
    I am using oneplus 6 and the display burn issue came in phone due to pubg high end graphics
  7. Scott Cunningham
    Eclair Jul 10, 2019
    Scott Cunningham , Jul 10, 2019 :
    I don't have screenburn what so ever and I play pubg and fortnight easiest solution is to play with low brightness for short periods of time anything longer and you will burn.
  8. borft
    Jelly Bean Jul 10, 2019
    borft , Jul 10, 2019 :
    nope, it doesn't occur because of high end graphics, it's because of static high brightness images. also, you're in the wrong forum.
  9. Waveform Modifier
    Marshmallow Jul 10, 2019
    Waveform Modifier , Jul 10, 2019 :
    And due to dumbness.
  10. Ajay Rana
    Cupcake Jul 12, 2019
  11. Mr_Cyrox
    KitKat Jul 12, 2019
    Mr_Cyrox , Jul 12, 2019 :
    Well you're drowning in the same ocean
    Your post doesn't help the thread in any way
    Ajay Rana likes this.
  12. Waveform Modifier
    Marshmallow Jul 12, 2019
  13. borft
    Jelly Bean Jul 12, 2019
    borft , Jul 12, 2019 :
    you're suffering from dumbness too?
    Waveform Modifier likes this.
  14. Waveform Modifier
    borft likes this.
  15. alimonu2011
    Eclair Oct 21, 2019
  16. Mr_Cyrox
    KitKat Oct 22, 2019
    Mr_Cyrox , Oct 22, 2019 :
    Good for you, now go do the scary thing known as reading
  17. Waveform Modifier
    Marshmallow Oct 22, 2019
  18. alimonu2011
    Eclair Oct 22, 2019
    alimonu2011 , via OnePlus 5 , Oct 22, 2019 :
    same
    #38
  19. guanyu210379
    Jelly Bean Oct 22, 2019
    guanyu210379 , Oct 22, 2019 :
    Wow! Someone managed to get OLED burn-in on a phone! That is one hell of an achievement.
    You must have played one single game a lot...and I mean...a LOT.
    Static image on same place for longer time will cause burn-in. Games tend to have something like this in the on-screen GUI part.
    Higher brightness and heat accelerate the burn-in.
    OLED screen can heal it self to some extend (very limited).
    Burn-in is a physical damage and if the screen already can not repair itself anymore, there is nothing you can do anymore to fix it except replacing the screen.
    For now, all you can do is try to contact Oneplus for repair (screen replacement) or go buy a new phone.
    #39
  20. guanyu210379
    Wrong! It is due to static image. not only due to games, things like TV-channel logo will have the same impact.
    #40
